Quick pH calculation - Please verify
  • Thread starter Thread starter alingy1
    Calculation Ph
The discussion focuses on calculating the new pH of a solution after mixing sodium hydroxide (NaOH) and sulfuric acid (H2SO4). Initially, a 50.0 mL NaOH solution with a pH of 12.50 contains 0.00158 mol of hydroxide ions (OH-). After adding 36.00 mL of 0.0200 mol/L H2SO4, the limiting reagent is H2SO4, resulting in 0.00014 mol of OH- remaining. The final pH of the mixed solution is calculated to be 11.21.
  • Understanding of acid-base chemistry and pH calculations
  • Knowledge of molarity and concentration calculations
  • Familiarity with stoichiometry in chemical reactions
  • Basic principles of solution mixing and volume addition
  • Study the Henderson-Hasselbalch equation for buffer solutions
  • Learn about titration curves and their significance in acid-base chemistry
  • Explore the concept of limiting reagents in chemical reactions
  • Investigate the effects of temperature on pH and solubility
Chemistry students, laboratory technicians, and anyone involved in acid-base titration and pH calculations will benefit from this discussion.
alingy1
Quick pH calculation -- Please verify
A 50.0 mL aqueous solution of sodium hydroxide has a pH of 12.50. If 36.00 ml of 0.0200 mol/L sulfuric acid is added to this sodium hydroxide solution, what will be the new pH of the resulting solution? Assume that the temperature stays constant at 25C, and that the volumes are perfectly additive.
50ml=0.05L
0.00158 mol OH- initially.
0.00072 mol H2SO4
Entire consumption of H2SO4(limiting reagent).
0.00086 mol OH- left.
0.00072 mol HSO4- left.
Entire consumption of HSO4-:
0.00014 mol OH- left.
Volume total=86 ml.
ph=11.21
Makes sense?
Looks OK.
How did you do all of it?
11K
