Quick question 1st law thermodynamics
The discussion focuses on the first law of thermodynamics, specifically regarding isothermal processes. The equation for heat flow in an isothermal system is given as ΔQ = ΔU + PΔV, where ΔU represents the change in internal energy and PΔV accounts for work done. It is established that if a system returns to its initial state on a PV graph, the total change in internal energy is zero, as both pressure and temperature remain constant, confirming that internal energy is dependent on temperature alone.
  • Understanding of the first law of thermodynamics
  • Familiarity with the ideal gas law (PV=nRT)
  • Knowledge of internal energy concepts (U = nC_vT)
  • Basic grasp of PV diagrams and isothermal processes
  • Study the implications of the first law of thermodynamics in various thermodynamic cycles
  • Explore the concept of heat transfer in non-isothermal processes
  • Learn about the relationship between work done and heat flow in thermodynamic systems
  • Investigate real-world applications of isothermal processes in engineering
Students and professionals in physics, engineering, and thermodynamics, particularly those interested in understanding heat transfer and energy conservation in thermodynamic systems.
ice87
What is the equation to find the change in heat of a system that is isothermal?
And also, for a PV graph, if the state of the system loops back onto itself, as in it starts at a and ends at a, is the total change in internal energy always 0?
Since PV=nRT, if T does not change, PV is constant. So the internal energy of the system does not change. As a result, there has to be heat flow to or from the system when work is done by or to the system (if it is compressed, heat is lost to the system; if it expands isothermally, it absorbs heat). The heat flow is: \Delta Q = \Delta U + P\Delta V = P\Delta V.
Yes. If PV is the same, T is the same (PV=nRT). Since U = nC_vT, if the temperature is the same and n does not change, internal energy is the same.
AM
  • · Replies 33 ·
  • · Replies 37 ·
