Manipulating a Laurent Series Equation
The forum discussion centers on manipulating a Laurent series equation, specifically the function \( g(z) = \frac{1}{z^4 \sin(z)} \). Users explored the equivalence of two expressions derived from multiplying both sides of the equation by \( z^5 \left(1 - \frac{z^2}{3!} + \frac{z^4}{5!} - \frac{z^6}{7!} + \ldots \right) \). After initial confusion and mistakes in proving equality, participants clarified that the series converges to 1 and discussed the proper approach to express \( f(z) = \frac{1}{z^5 \sin(z)} \) as a Laurent expansion. The discussion highlighted the importance of correctly applying Taylor series and managing signs in series expansions.
  • Understanding of Laurent series and their applications
  • Familiarity with Taylor series expansions
  • Knowledge of sine function expansions and their properties
  • Experience with manipulating power series in complex analysis
  • Study the derivation and properties of Laurent series in complex analysis
  • Learn about Taylor series and their convergence criteria
  • Explore the Cauchy Residue Theorem and its applications in evaluating integrals
  • Practice manipulating power series through examples and exercises
Mathematicians, students of complex analysis, and anyone interested in series expansions and their applications in mathematical proofs and evaluations.
cpburris
Show the following:
{\frac{1}{z^5\left(1-\frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+...\right)}}={{\frac{1}{z^5}}+{\frac{1}{6z^3}}+{\frac{7}{360z}}+{\frac{31z}{15120}}+{\vartheta({z^3})}}
None
Not really a homework problem, just an equation from my textbook that I do not understand. I can't think of any way to even begin manipulating the right hand side to make it equal the left hand side.
Just to confirm equality (thanks to another user for suggestion), I multiplied both sides by of the equation by
##{z^5\left(1-\frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+...\right)}##
to see if the right hand side equaled one. So,
##{z^5\left(1-\frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+...\right)}\left({\frac{1}{z^5}}+{\frac{1}{6z^3}}+{\frac{7}{360z}}+{\frac{31z}{15120}}+{\vartheta({z^3})}\right)=\left({z^5}-\frac{z^7}{3!}+\frac{z^9}{5!}-\frac{z^{11}}{7!}+...\right)\left({\frac{1}{z^5}}+{\frac{1}{6z^3}}+{\frac{7}{360z}}+{\frac{31z}{15120}}+{\vartheta({z^3})}\right)##
##=1+\frac{z^2}{6}-\mbox{ no terms of order }z^2+...##
With no other terms of order ##z^2## it isn't clear to me that the series should converge to one.
Edit: Working on trying to figure something out, will update with any progress. Also thank you to whoever edited my title!
Edit 2: Some mistakes were made in my attempt to show the equality. Looking at it again after taking a break I was able to show that indeed both sides of the equation are equivalent.
Not clear if you want to do this on your own, or if you need assistance.
Several approaches are possible. What path do you have in mind ?
[edit]
Can you tell us a bit more what you mean with that ?
Maybe my brain is just fried from too much studying, but I really cannot come up with where to start. I edited the post with an attempt to just show that the equality is valid, but that just confused me more. I would appreciate someone just giving me a full explanation but any assistance or hints you can provide would be great.
[edit]
Sure, I will try. I have dealt with plenty of problem where
functions such as
##\frac{1}{x^2-1}## which have denominators which are sums can be transformed into a sum of fractions via a Taylor Expansion. This is however an example where the denominator is already an infinite sum, and I do not understand how that can be separated into a sum of (infinite) terms. Does that make sense?
Edit: This all comes from an expansion of the sine function in the function ##g(z)=\frac{1}{z^4sin(z)}## in order to show that g(z) can be expressed as a Laurent expansion, in order to then discuss Cauchy Residue Theorem if that helps any.
your approach seems sound. in general, in my experience all computations of inverses of power series proceed from the basic; 1/(1-t) = 1 + t + t^2 + t^3 +..., using various substitutions for t.
In the step $${z^5\left(1-\frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+...\right)}\left({\frac{1}{z^5}}+{\frac{1}{6z^3}}+{\frac{7}{360z}}+{\frac{31z}{15120}}+{\vartheta({z^3})}\right)=\left({z^5}-\frac{z^7}{3!}+\frac{z^9}{5!}-\frac{z^{11}}{7!}+...\right)\left({\frac{1}{z^5}}+{\frac{1}{6z^3}}+{\frac{7}{360z}}+{\frac{31z}{15120}}+{\vartheta({z^3})}\right)$$ you take the ##z^5## into the first bracket. It's easier to take it into the second.
Then you make a mistake: $$\Bigl (1-{z^2\over 6}...\Bigr )\Bigl (1+ {z^2\over 6} ...\Bigr )$$ has no terms of order ##z^2## !
Ok, after a good nights rest I revisited the problem and was able to properly prove the equivalence of both expressions. However it is still not clear to me how to go about expressing
##f(z)={\frac{1}{z^5\sin(z)}}={\frac{1}{z^5\left(1-\frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+...\right)}} \mbox{ as a Laurent expansion } f(z)=\sum\limits_{n=-\infty}^{\infty}a_nz^n##
Edit: Mistakenly put ##\theta## as the argument of the sine function out of habit. Corrected to be ##z##.
As mathwonk suggested earlier in the thread, you use the Taylor series ##\frac{1}{1-t} = 1+t+t^2+\cdots##. Write
$$\frac{1}{z^5\left(1-\frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+\cdots\right)} = \frac{1}{z^5(1-t)}=\frac{1}{z^5}(1+t+t^2+t^3+\cdots),$$ where ##t = \frac{z^2}{3!}+\frac{z^4}{5!}-\frac{z^6}{7!}+\cdots.##
Likes benorin
This is precisely as Knopp directs to divide power series in his book "Theory and Applications of Infinite Series," 2nd edition, pgs. 179-181.
OK that all makes sense. I believe I understand it now. Thank you everyone for your help and advice.
but watch your minus signs. for 1-t to equal 1 - z^2/3! + z^4/5! ..., you have to change the signs of every term after the 1, not just the first term z^2/3!, i.e. you need t = z^2/3! - z^4/5!...
