Quotient of First Order Ordinary Derivatives
franklampard8
How do you solve (analytically or numerically) a differential equation of this form,
$$\frac{\mathrm{d}y(x)/\mathrm{d}x}{\mathrm{d}z(x)/\mathrm{d}x} = a[1-y(x)-z(x)] + b$$
where a, b are constants. Also,
$$y(0) = z(0) = 0$$
$$y(0) = z(0) = 0$$
Since you have only one equation, but two unknown functions y(x) and z(x) the problem remains undefined. You cannot obtain one function y(x) and one function z(x), but an infinity of couples.
Nevertheless, tne differential equation allows to express a relationship beteween each couple y(x) and z(x). The relationship is on the form y=function of z.
Now, how to obtain y = y(z) ?
dy/dz = a(-y-z)+b
(dy/dz)+a*y = b -a*z
(dY/dz)+a*Y = 0 --> Y = c*exp(-a*z)
c --> f(z)
y = f(z)*exp(-a*z)
dy/dz = (df/dz)exp(-a*z)-a*f*exp(-a*z)
(df/dz)exp(-a*z)-a*f*exp(-a*z) +a*f*exp(-a*z) = b -a*z
(df/dz)exp(-a*z) = b -a*z
df = (b-a*z)exp(a*z)*dz
f = (1/a)*(-a*z+b+1)*exp(a*z)+C
y = (1/a)*(-a*z+b+1) +C*exp(-a*z)
y(0)=z(0)=0 --> 0 = (1/a)*(b+1) +C --> C = -(b+1)/a
y = (1/a)*(-a*z+b+1) -((b+1)/a)*exp(-a*z)
if you want, you can chose any derivable function z(x). Then, the related function y(x) is :
y(x) = (1/a)*(-a*z(x)+b+1) -((b+1)/a)*exp(-a*z(x))
This proves that, due to the incomplete wording, there are an infinity of solutions.
Or did you originally have two equations, one for dy/dx and one for dz/dx and you performed the 'trick' where you divide one by the other to end up with one differential equation?
You would then probably get an ode like dy/dz = a(1-y-z)+b which is linear.
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
