R = Kx^2 / mg <- anybody reconise this?
  • Thread starter Thread starter StheevilH
The formula R = Kx² / mg is derived from the principles of conservation of energy and projectile motion, specifically when a spring is used to launch a projectile at a 45-degree angle. In this context, R represents the range or displacement, K is the spring constant, x is the extension of the spring, m is the mass of the projectile, and g is the acceleration due to gravity. The discussion emphasizes the relationship between potential energy (PE) and kinetic energy (KE), leading to the conclusion that the initial and final velocities are equal when the projectile reaches the same height.
  • Understanding of conservation of energy principles
  • Familiarity with projectile motion equations
  • Knowledge of potential energy in springs (PE = 1/2 K x²)
  • Basic trigonometry, particularly sine functions
  • Study the derivation of the conservation of energy equation: PE + KE = constant
  • Learn how to apply projectile motion equations, especially the range formula R = Vo² * Sin(2θ) / g
  • Explore the relationship between initial and final velocities in projectile motion
  • Investigate the effects of launching angles on projectile trajectories
Physics students, educators, and anyone interested in understanding the mechanics of springs and projectile motion will benefit from this discussion.
StheevilH
R = Kx^2 / mg <-- anybody reconise this?
Well..
I had experiment about springs...
I got this R = K x^2 / m g.. formula to explain...
where
R = range (displacement of x)
K = constant of spring (elastic)
x = extension of spring
m = mass
g = gravity
Can anybody prove this formula for me??
It says use conservation of energy and 4 formulae of projectile motion..
I'd really appreciate if anybody can prove it...
PS it is fired at angle of 45 degrees
Welcome to PF!
Hi StheevilH! Welcome to PF! :smile:
uh-uh … you have to do the work! :smile:
First write out the equation of conservation of energy, as it applies to the spring and the projectile.
Then write out as many equations for projectile motion as you can think of.
What do you get? :smile:
Eh... write out as many equations for projectile motion?
I learned only 4 types of them though... and none of them matchs..
Before that...what is the equation of conservation of energy??
I don't get the whole thing..to begin with...so..would you be able to be more detail??
please?? =]
Wait.. don't worry about the above one I wrote...
I found out potential energy of the spring is 1/2 * K * x^2..
but this doesn't match with any projectile formula I got..
is x = Vx?
or V itself? not in component form?
Gah...I'm not good at this...
Waiting for a reply...
Hi StheevilH! :smile:
(btw, is the spring launching a separate projectile, or is the spring itself a projectile? :confused:)
No, your PE won't fit into a projectile formula … it'll fit into a conservation of energy formula! :wink:
And conservation of energy is PE + KE = constant …
so what formula do you have for KE? :smile:
Ah...I worked out...I think...
lol..yeah I thought PE was meant to be in projectile formula..
Eh...from what I got...is KE = PE...
1/2 * K * x^2 = 1/2 * m * v^2
Hence, v^2 = K * x^2 / m ..
Using range formula; R = Vo^2 * Sin 2 (*) / g..
R = K * x^2 / m * g...Sin 2 (45) = 1...so can be ignored...
though...
I don't get how initial velocity and the final velocity can be same?
Can you tell me how they works?
Spring itself is the projectile motion...yeah...I think...lol
Thanks if you tried!
Oh..don't forget to reply my last question =]
though...
Conservation of energy again … initial and final velocity are at the same height … so PE is the same … so KE must be the same! :biggrin:
Alternatively, just look at the curve the projectile follows … it's a parabola, and it's symmetric … so speed and angle on the way up will always be equal and opposite to speed and angle at the same height on the way down. :smile:
Sorry … what question? :confused:
Oh..lol question...
That was pointing at the Vo being equal to V...
So... we can ignore about the directions in the calculations??
The magnitudes are same...so we can just put them as same?
and...did I actually get it that way.. @_@
No … don't forget the sin2 factor … at 45º, it just happens to be 1, but you would usually have to include it. :smile:
Roger, copy that
(Y)
  • · Replies 21 ·
