- 449
Drawing the suspension
here as are the steps to design your suspension. Either draw a 1/4 scale model or use the cut outs to replicate the components.
Draw the Ground line, vehicle center line and center of the left and right front tire contact patch. It is assumed you have the tires mounted on the wheels you are going to use and you have the spindle attached to each one. If you are totally starting from scratch..follow along and you will need to work backwards from the end result. Determine where the outer lower ball joint centers ( could also be rod ends) are to the spindle by bolting them to the spindle. Mark the BJ centers on the drawing. ( note- you can input this data into the software package of your choice..I use circle track analyzer from performance trends)
Determine the Roll Center you want and mark it down.
we want the instant center of the left ft and rt. ft a-arms/control arms/wishbones to be 2 inches inside the opposite lower BJ. draw a vertical line from ground to each location and label as Instant Center vertical plane.
Find out the kingpin angle of the spindle and the amount of static camber you want to use. Most stock cars use 10 degree king pins and we normally run 3 degrees camber on the right front so draw a 13 degree angle from the rt. lower BJ vertically. Same with the left side.
Determine the location of the pivot center of each upper BJ. Measure the lower BJ center to the upper BJ center.
Draw a line from the center of the rt. ft. tire contact patch thur the RC to the Instant Center Vertical plane on the left side. The intersection point is the Instant Center (IC) of the right side suspension.
Draw a line from the Rt. ft. IC to the rt. ft lower BJ center.
Repeat the process to get the left ft. IC point.
Now that you have the lines from the IC to the upper and lower BJ centers, the point of convergence is the location of the lower inner pivot points for the lower control arms and this mounting point must fall along these lines.
The only thing left to do is connect the dots and figure the length of the upper and lower control arms. One wrinkle is the fact that the steering rack will impact on lower control arm length. The steering rack tie rods travel must straight in line with the lower a-arms so we don't run into bump steer. The inner tie rod ends of the steering rack must be in line with the lower a-arm inner pivot points to avoid this.
The upper inner a-arm pivot points are located where you want your camber curve to be. By this I mean you have to find the location of the upper and lower BJs move 3 inch in Bump travel. Draw a horizontal line 3 inch above the lower BJ center. Use a compass and stick the point into the lower inner pivot point and place the pencil in lower bj center. swing the arc up to the 3 inch line. Now you know the location of the lower Bj in 3 inch of bump.
The inner upper pivot point for the upper a-arm is found by trial and error. The correct inner upper a-arm location is found by swinging arcs about different locations on the upper a-arm instant center line until the correct angular change is found. The correct angle will connect the static upper BJ center wit the intersection of the 3 inch horizontal bump travel line. the software program makes all of this a lot easier and is worth the $ 100 cost ..in sanity and cost of beer consumed drawing this stuff..
