paweld
- 253
Why according to QFT accelerating electron radiates? What is the vertex in Feynman diagram for this proces.
Count Iblis said:The conventional view (also explained in the book by Itzykson & Zuber) is that within classical electromagnetism one cannot give a fully rigorous derivation of the radiation emitted by an accelerated charge.
The source of the problem is actually quite easy to understand. If a charge is accelerated by an electric field and it radiates, it loses the energy and momentum in the radiation. So, the force on the charge is not given by the applied electric field times the charge. But, by assumption, only electromagnetic fields can interact with the charge. So, to correctly describe the motion of the charge from first principles, one would have to consider the interaction of the charge with the total electromagnetic fields, which consists of the applied field plus the fields generated by the charge itself.
Now, in principle, one would always have to include the intereaction of the charge with its own field, but this, of course, leads to infinities. But one can ignore this problem in case of non accelerating charges as the net effect of the self-interaction should vanish.
For accelerating charges this is no longer true (indeed, it is the very source of the energy and momentum radiated by the charge). But in the 19th century and early 20th century, this problem was never satisfactory solved. The theory leads to either equations that allow a charge to undergo runaway accelerations in the absense of an applied field. Or, you end up with pre-acceleration. I.e. if you suddenly switch on a field at t = 0, the charge starts to accelerate slightly before t = 0.
Recently a solution of this problem was proposed here:
http://arxiv.org/abs/0905.2391
paweld said:Why according to QFT accelerating electron radiates? What is the vertex in Feynman diagram for this proces.
paweld said:Thanks for your answer.
I have one more question. Do you understand why the radiation isn't seen in the
frame of reference of the charge. I heard that the energy of emmited quanta is
equal 0 in this frame so they cannot be detected.
