Radiation reaction force and Newton's third law
The discussion centers on the issue of radiation reaction force in a rotating charged sphere system. As the sphere emits radiation with power P, it experiences a slowing of its rotation due to the radiation reaction force, defined as F = P/V. Calculating the maximum force from emitted radiation reveals that the impulse generated by radiation (F1 = P/c) is less than the radiation reaction force (F), indicating an imbalance. This suggests that not all emitted radiation moves in the same direction, further complicating the relationship with Newton's third law. The conversation raises questions about the nature and implications of the radiation reaction force in this context.
goran d
There seems to be a problem with radiation reaction force.
Let's look at charged sphere, attached on a rod to an object with larger mass, and rotating around its centre together with it.
The rotating charged sphere emits radiation with power P.
The sphere's speed is V.
Assuming energy is conserved, the rotation is slowed down by radiation reaction force.
The radiation reaction force's magnitude is F
P=FV
F=P/V
Thus we find the force.
Now let's find how much maximum "force" would the emitted radiation create.
The energy of radiation:
E=mc2
The impulse of radiation:
p=mc
p=E/c
we differentiate both sides with respect to time
F1=P/c
Where F1 is the force that the radiation would create if all of it were to move away in the same direction as the motion of the sphere.Clearly F1<F, so the radiation is not sufficient to supply the radiation reaction force. And even more, not all radiation is going to "shoot" in the same direction, so the difference is even greater. So the radiation reaction force must therefore be unbalanced, contrary to Newton's third law!
F1=F(v/c)
Science news on Phys.org
"The radiation reaction force's magnitude is F
P=FV
F=P/V
Thus we find the force."
Where does this come from? What kind of force you refer to here?
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
