Why Does My Java Random Insult Generator Not Compile?
  • Context: Java
  • Thread starter Thread starter GobiasMoleman
    Generator Random
The discussion revolves around troubleshooting a Java program intended to generate random insults. Participants explore issues related to compilation errors, syntax, and the structure of the code, as well as the potential applications of such a program.
  • One participant notes that the variable lengths for arrays are being accessed before they are defined, which could lead to errors.
  • Another suggests a syntax error related to spacing in the assignment of the Random object.
  • Some participants comment on the classification of "goatstealing" as an adjective rather than a verb, with differing opinions on its usage.
  • Several participants provide alternative code snippets and suggestions for structuring the program to avoid errors.
  • There are humorous remarks about the quality of the insults generated and their relevance in a politically correct context.
  • A participant shares a personal anecdote about using a similar approach in a different programming language, emphasizing the importance of managing words effectively.
Participants express various opinions on the code's structure and potential errors, but there is no consensus on a single solution or approach. Disagreements exist regarding the classification of certain words and the overall effectiveness of the generated insults.
Some participants highlight the importance of defining variables before use, while others suggest that certain syntax issues may not be critical. The discussion reflects a mix of beginner-level programming challenges and humorous commentary on the nature of the project.
GobiasMoleman
I need to make this Random Insult Generator work... I mistakenly thought it had compiled correctly, but I guess something went wrong. I would really appreciate some help with this as soon as possible. Thanks (I apologize for the sloppy code, I just saw Java code for the first time a few weeks ago, so this is pretty alien to me):
//InsultGenerator
//A program to generate insults.
import java.text.*;
import java.util.*;
import java.util.Random;
public class InsultGenerator
{//start
public static void main(String[] args)
{//start main
//variables
Random choice =new Random();
int a = choice.nextInt(adj.length);
int b = choice.nextInt(verb.length);
int c = choice.nextInt(noun.length);
//insult
{//start insult
String adj[] = { "poxmarked", "cantankerous", "bilestained", "scruffy looking"};
String verb[] = {"goatstealing"};
String noun[] = {"nerf herder", "blackguard"};
}//end insult
//Text
System.out.println("You "+adj[a]+", "+verb+" "+noun[n]+".");}
}//end main
Technology news on Phys.org
It would help to know what your error was :\
I never used Java but if it's a syntax error you're getting:
Put a space between '=' and 'new'.
Side note: 'goatstealing' is an adjective, not a verb.
I wonder what this program can possibly be used for...
You would wonder that, you poxmarked, goatstealing blackguard!
I am not terribly familiar with Java, but it looks like you are using the length of adj verb and noun before they are defined.
At the line
the variable adj has not been defined so its length is also undefined (or at best 0)
Yes, and the insult section doesn't need braces (though I don't think they hurt).
:smile: Those are some weak insults.
Is this an attempt at an artificial Rodney Dangerfield ? That's not AI ...hehe it lacks the I part ... j/k it's a good start at programming.
Half is learning the silly syntax, half is learning what the routine is doing.
I always found the first half harder.
Yeah, but in our over-sensitive politically-correct world a really good one would probably get you expelled :frown:
Damn right!
It can be used for either, right? I was called a goatstealing fiend after I got caught goatstealing.
Do testing :smile:
Some suggestions:
Code:
{//start main
//variables
//Text
System.out.println("You "+adj[a]+", "+verb[b]+" "+noun[n]+".");
Code:
{//start main
//variables
String noun[] = {"nerf herder", "blackguard"};//Text
System.out.println("You "+adj[0]+", "+verb[0]+" "+noun[0]+".");
Code:
{//start main
//variables
System.out.println(" a = "+a+" b = "+b+" c = "+c);
If you don't find any problem, try compiling again or use different computer .. or restart ;)
your mother is so fat ...
filling this in could substitute for a test grade in linear algebra perhaps.
I did this once back in VB6 but I loaded up all my "literary devices" into text files then randomized results from those. It helps give you an easy way of managing your words.
But yeah, it just looked like you tried using the objects before they were instantiated(created).
9K
  • · Replies 37 ·
