Raspberry Pi 4 Website Up-Time Monitor
  • Context: Computer
  • Thread starter Thread starter Greg Bernhardt
    Monitor Pi Raspberry pi
22 replies · 3K views
For a quarantine project I bought a Raspberry Pi 4 and a breadboard accessory kit. It won't arrive for another couple weeks, but I as super excited to dive in. My first project will be to create a simple LED up time monitor for PF :)
Anyone have some "must read" tutorials? I'll be using python.
on Phys.org
I assume there is an atomic time feed available somewhere which you could import. IIRC it uses RSS features, but I'm not sure, it is too long ago. I once had a "clock page" which displayed the "real time". Real time is local minus three hours: night owl time!
Won't do anything "real-time". Just a simple ping every second.
For that even Pi Zero would be an overkill.
At the moment I have five Pi running (I think 2, 2, 3, 0, 0, not entirely sure about exact models). One for automatic backups (about 2 MB per day, so a 64GB SD card will most likely survive me), one for monitoring the street outside, one for my weather station, one for my birdhouse and lately testing one as an NFS with a mechanical HDD attached. NFS is way too slow for any serious application, but I hope it will solve a recurring problem with the street camera - it fills 32 GB in a week (rotating the data) and kills a 32 GB pendrive in about 2 years (typical flash memory doesn't survive more than about 100 writes).
I am not saying these are all I have :wink:
Well, your machine will be executing machine instructions, when probably some interpreter is parsing your Python -- I think that you already know that some of the PF members, e.g. @jedishrfu and @Mark44, could be go-to guys for you if you decide to look for some assistance -- I'll try to pitch in if I think that I might be able to say something worthwhile ##\dots##
That's great Greg! Don't forget to wipe down the box and packaging before touching it as there have been some COVID related isolated instances of Amazon employee protests.
Getting Started with Raspberry PI by Richardson and Wallace (OReilly pub)
Raspberry Pi in Easy Steps (full color) by McGrath
Both are newbie books but sometimes you can find what you need clearly explained.
First you'll have to choose an OS:
https://raspberrytips.com/best-os-for-raspberry-pi/
I have mine configured with Raspbian. It helps to know Python and Linux for any Raspberry PI work although you can also use C.
https://stackoverflow.com/questions/39371772/how-to-install-anaconda-on-raspberry-pi-3-model-b
I've heard that Processing can be run to Raspberry PI but while I like using it I've not installed it yet (I think you need Java and Processing and perhaps some other stuff).
https://pi.processing.org/get-started/
I've also heard that the Anaconda 3 distribution of python can be installed. Anaconda comes with a ton of python modules for doing data science and machine learning... I've installed it on my regular computers and have used the Flask api to created a simple web service.
Lastly, Pycharm is the goto IDE for python development, Jetbrains has a writeup on how to use it to do remote debug on a Pi:
https://www.jetbrains.com/help/pycharm/remote-development-on-raspberry-pi.html
I also use Raspbian for my Pi.
And here is a GitHub website uptime project you can take a look at, but you could just use standard Linux commands in a shell to do this, Python is considerable overkill unless you are planning to maintain tracking statistics (and even then, shell can probably do the job) 🤔
It came in the mail... now I just need to order the power supply and mini HDMI converter, whoops :smile:
Yup, been there, done that. o0)
Did you order a case for it already? It's good to put it into its plastic case to protect it. Also, did it come with a micro-SD card, or do you already have some? The Pi's we order don't come with one, so we've ordered a bunch for our lab stock.
https://www.raspberrypi.org/documentation/installation/sd-cards.md
LOL, I always buy a batch - Pi, power supply, SD card (micro these days, but the old Pi used the standard ones).
An excellent use of time - but be careful, this is addictive!
https://www.raspberrypi.org/documentation/usage/python/ - by the second page of that you'll have the LED lit up!
Raspbian (the Pi-specific flavour of Linux that is best for use on the Pi) will automatically use NTP to synchronise system time with a server as soon as you give it an internet connection.
But you will want to write a log of down times in the next version, so will need a synchronised clock.
Just go with Raspbian until you find a reason not to (and unless you like getting down and dirty at the OS level, like @jedishrfu @sysprog and of course me, you won't find a reason :smile: ).
I'd only recommend this if your tutorial uses Anaconda, or more specifically conda for package management. Most Pi tutorials don't (they use pip): there is a version of Anaconda called Miniconda but it is a bit of a niche.
PyCharm is great but again it is a bit of a niche on the Pi so again I'd just go with whatever your tutorial uses - the official Rasperry Pi Foundation one I linked at the top uses Thonny.
But shell is a dead end, and working out how to work the LED display (will this be a 7-segment display, or perhaps a 128x64 OLED?) would be a pain. There is no reason NOT to use Python which will both make the basic task much easier and also enable unlimited future development.
Whoops indeed - hope Amazon is still pretty quick where you are. Also is it a Pi specific breadboard kit you have got - if not then one of these to connect to the Pi's GPIO connector is much better than hooking up individual wires:
https://www.amazon.com/dp/B01N562X2P/?tag=pfamazon01-20
Enjoy!
PS I use Node on my Pis rather than Python but there is 100x more Python stuff around for the Pi, it is what it was designed for so I'd recommend you go with that unless you specifically want to learn Node.
Wow that was a great post @pbuk.
Wow, that's an even worse habit than mine! Although I also have rather a lot of microcontrollers...
I just moved, so I am not getting into any Pi projects right now. I was planning on building a Pi cluster at one point in time, just for giggles to start playing around with parallel programming since my old job was to extend a code to distributed memory processing.
Very cool, Greg! I especially like that you color coded the wiring to the Red and Green LEDs. Nice touch. :smile:
Three annoyances.
1. Some LEDs dimly light up even if their state is powered off.
2. The right half of my breadboard is busted, nothing on the right gets powered. The GPIO extension board is fine though.
3. Having issues getting the script to write to a cvs file. Works fine in console, but in Cron, it won't write and no errors. Files and folders are all 777. I'm stuck.
Python:
#!/usr/bin/python3
from gpiozero import LED #for breadboard
from datetime import date #get today's date
from datetime import datetime #get today's date
import lcddriver #for lcd screen
import requests #for header info
import time #for time delay
import csv #for record keeping
#register lcd driver function
display = lcddriver.lcd()
# start up time function
def uptime(url,name,gLED_num,rLED_num,bLED_num):
    #check url header
    response = requests.get(url)
    status_code = "Status Code: " + str(response.status_code)
    #define LED colors and locations
    greenLED = LED(gLED_num)
    redLED = LED(rLED_num)
    blueLED = LED(bLED_num)
    #if server responds with header 200 light up green LED and display message on LCD
    if response.status_code == 200:
        gettime = round(response.elapsed.total_seconds(),2)
        display.lcd_display_string(name + " Speed:" + str(gettime), 1)
        display.lcd_display_string(status_code, 2)
        for x in range(0,5):
            greenLED.on()
            time.sleep(0.1)
            greenLED.off()
            time.sleep(0.1)
            if gettime > 1:
                blueLED.on()
                time.sleep(0.1)
                blueLED.off()
                time.sleep(0.1)
    #if not 200 then light up red LED and display message on LCD
    else:
        display.lcd_display_string(name + " is Down", 1)
            redLED.on()
            time.sleep(0.1)
            redLED.off()
            time.sleep(0.1)
    #Leave on LCD do I can have time to read
    time.sleep(1)
    #cleanup
    display.lcd_clear()
    greenLED.off()
    redLED.off()
    blueLED.off()
    # write to CSV for historical usage
    now = datetime.now()
    today = date.today()
    getnow = now.strftime('%H:%M')
    getdate = today.strftime('%m/%d/%Y')
    with open("uptime_" + name + ".csv", "a") as uptime_file:
        uptime_writer = csv.writer(uptime_file, delimiter=",",quotechar="'", quoting=csv.QUOTE_MINIMAL)
        uptime_writer.writerow([getdate,getnow,name,response.status_code,gettime])
    #debug
    #print(str(getdate) + " " + str(getnow) + " " + name + " " + str(response.status_code) + " " + str(gettime))
#site1 Monitor URL,greenLED,redLED,blueLED WORKS
uptime("https://www.site1.com/","site1",18,23,17)
#site2 Monitor URL,greenLED,redLED,blueLED
uptime("https://www.site2.com/","site2",27,25,5)
#site3 Mon itor URL,greenLED,redLED,blueLED
uptime("https://www.site3.com/","site3",20,16,26)
#site4 Monitor URL,greenLED,redLED,blueLED WORKS
uptime("https://www.site4.com/","site4",21,12,24)
oh derp, the file was relative, changed to absolute and it works!
That's what I was about to suggest :)
Could be a problem with your breadboard shorting, or it could be that some other process is reconfiguring the pins as input pins when your script isn't running (I assume you mean the LEDs are dimly on while the script is not running between cron hits?)
The quality of this kind of stuff is variable, not surprising as it is ridiculously cheap. I have found Elegoo to be more reliable than others.
Already solved and perhaps it's nitpicking but you should never need to use 777 permissions; your Python code runs as you so 644 (files)/755(directories) is plenty.
