Rate of water through a conical cone, in order to find constant k
The problem involves a water tank shaped like a vertex-down right circular cone, with specific dimensions and rates of water flow in and out. The goal is to find the constant k related to the rate at which water leaks out of the tank, given the depth of water and the rate of change of that depth.
  • Mixed
  • Participants discuss the relationship between the volume of water in the tank and the rates of water flowing in and out. There are attempts to differentiate the volume equation and relate it to the rates provided.
Some participants have provided guidance on how to set up the equations based on the problem statement, while others have raised questions about the assumptions and calculations made. There is an ongoing exploration of how to isolate the variable k and clarify the relationships between the variables involved.
There is some confusion regarding the rates of water flow, particularly the correct interpretation of the rate at which water is poured in and how it relates to the leaking rate. Additionally, a correction was made regarding the volume of water being 14π cubic meters per hour instead of 14 cubic meters per hour.
i_m_mimi
[10marks] A water tank has the shape of a vertex-down right circular cone. The depth
of the tank is 9 meters, and the top of the tank has radius 6 meters. Water
flows into the tank from a hose at a constant rate of 14 cubic metres per
hour, and leaks out of a hole at the bottom of the tank at a rate of kh cubic
metres per hour when the depth of water in the tank is h metres. Here k is a
constant. When the water is 3 metres deep in the tank, its surface is rising at
the instantaneous rate of 2 metres per hour. Find the value of the constant k.
Answer: k = 2pi
V = 1/3 pi r^2 h
made so many attempts on paper, including
r/h = 6/9
V = 1/3pi (6h/9)^2h = 4/27pi h^3
rate of change in volume = rate which water is poured in minus rate water leaks out
V' = 14pi m^3/hour - X
X = rate water leaks out
V' 12/27 (h^2)(h')
h' = 3
V' = 2/3 pi r r' h + h' pi r^2
V' = 2/3 pi (2)(2)h + (3) pi (2)^2
V' = 8/3 pi h + 4pi
X = 14pi - 8/3 pi h + 4pi
X = 10pi - 8/3 pi h
I'm not sure how to change the equation into rate water leaks out = kh form,
i keep on getting solutions where h is either not present or h^2
I think I've made mistakes somewhere in there and it is a complicated question worth 10 marks and with 20 minutes allocated to it on an exam.
thank you
"X= rate at which water leaks out"= kh, since you are told that the water leaks out at "at a rate of kh cubic
metres per hour". So the net "water in" is the rate at which it is coming in, 14 cubic meters per hour, minus the rate at which it is leaking out, kh. The net water in is 14- kh.
The rest you have done correctly. Yes, the ratio of radius of the top of the water to its height is that of the whole conical tank, r/h= 6/9= 2/3 so r= (2/3)h. The volume of a cone with height h and radius r is [itex](1/3)\pi r^2h[/itex] which, with r= (2/3)h, is [itex]V= (4/27)\pi h^3[/itex].
Differentiating both sides with respect to time, t, [itex]dV/dt= (4/9)\pi h^2 dh/dt[/itex].
You kind of lose me with the rest since you have stopped writing full equations.
Putting together the fact that the volume is changing at [itex]dV/dt= (4/9)\pi h^2 dh/dt[/itex]
with the fact that water is coming in at a net 14- kh, we have
[tex]\left(\frac{4}{9}\right)\pi h^2 \frac{dh}{dt}= 14- kh[/tex]
which we can write as
[tex]\frac{h^2}{14- kh}= \frac{9 dt}{4\pi}[/tex]
To integrate on the left, use the substitution u= 14- kh so that du= -k dh or dh= -du/k.
h= (u- 14)/k so that [itex]h^2= (u^2- 28u+ 196)/k^2[/itex] and the integral becomes
[itex]-\frac{1}{k^3}\int \frac{u^2- 28u+ 196}{u} du[/itex]
[itex]= -\frac{1}{k^3}\int \left(u- 28+ \frac{196}{u}\right)du[/itex]
Something seems off about the problem statement. You'd expect kh to be a positive number, but since:
dV/dt = 4/9*pi*h2*dh/dt = 4/9*pi*32*2 m3/h ≈ 25.1 m3/h
that can't be the case, i.e. the solution k = 2*pi is wonky aswell.
I made a mistake in copying the question. Water from the hose pours in at a rate of 14pi cubic meters/hour instead of 14, if that makes things simpler. However, I'm still confused.
I solved to the point of getting the integral you got following what you did.
I got something like 98-14kh + (k^2)(h^2) - 392 + 28kh + 28kh + 196ln(14-kh) = 0
Not sure where to go from here.
If you got this far:
[tex]\left(\frac{4}{9}\right)\pi h^2 \frac{dh}{dt}= 14 \pi- kh[/tex]
Then just solve for k and plug in the information given in the problem statement.
I get something like
if h' = 3 since r' = 2
12/9 pi h + 14pi/h = k
Not sure how to isolate for so its 2pi h?
Have a look at the problem statement again, you're looking for information about h and dh/dt at some point in time.
Keep in mind that dh/dt means the instantaneous rate of change of h with respect to time.
omg that's great i get it now :D
That means h' = 2, not r' = 2
4/9 pi (3)^2 (2) = 14pi - 3k
k = 2pi
thanks so much
Good job :smile:
