Understanding Rational Inequalities: Why Can't We Multiply by the Denominator?
  • Thread starter Thread starter rambo5330
    Inequalities
Rational inequalities require careful handling of the denominator to avoid sign changes that can alter the inequality's direction. Multiplying by the denominator (1-x) is valid only when its sign is known; if x > 1, (1-x) is negative, reversing the inequality. For x < 1, the inequality remains preserved, allowing for subtraction of 1 from both sides to simplify the expression. Alternatively, multiplying by (1-x)² ensures the sign remains positive, leading to valid solutions. The discussion emphasizes the importance of considering the sign of the denominator when manipulating rational inequalities.
rambo5330
Quick question on Rational Inequalities..
Say I have
\frac{1+x}{1-x} \huge\geq 1
Why can we not multiply 1 by denominator (1-x) is this because if x > 1 then (1-x) would be negative in effect changing the sign of the inequality.. but if x<1 then the inequality is preserved? therefore we subtract 1 from either side..setting the inequality equal to zero?
sorry the formatting isn't quite right on that expression but the left hand side is all one expression .. greater than or = 1
Yes.
You can do this as well.
Alternatively, you can multiply by (1-x)2.
What you can do is think "IF 1- x> 0, then I can multiply both sides by it and get 1+ x\ge 1- x". Add x to both sides and subtract 1 from both sides and you have 2x\ge 0 which is the same as x\ge 0. Now that was assuming 1- x> 0 which is the same as 1> x. So you have 0\le x&lt; 1.
Now, IF 1- x< 0, multiplying both sides by a negative number reverses the inequality: 1+ x\le 1- x. Again, add x to both sides and subtract 1 from both sides and you have 2x\le 0 or x\le 0. The "IF" is true as long as 1< x which can't be true if x\le 0 so this gives NO new solution.
The algebra gets a bit complicated but, yes, you can subtract 1 from each side: \frac{x+1}{1-x}- 1= \frac{x+ 1- (1- x)}{1-x}= \frac{2x}{1-x}\ge 0 which is true as long as the numerator and denominator have the same sign.
That is, both 2x> 0 and 1- x> 0 which gives x> 0 and x< 1 as before, or both 2x< 0 and 1- x< 0 which gives x< 0 and x> 1 which is impossible.
thanks for the excellent explanation!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
