Rationalizing Denominators: Understanding the Process
  • Thread starter Thread starter majormuss
The discussion revolves around the confusion regarding the rationalization of a denominator involving roots. The key point is that to rationalize the denominator of a term like 1/√[n]{x^m}, one must multiply by √[n]{x^{n-m}} to achieve a perfect power inside the root. In this case, using x^2 instead of x^3 was necessary to ensure that the product results in x^5, which simplifies to x when taking the fifth root. The focus is on ensuring that the expression under the root becomes a complete power corresponding to the root being used. The clarification provided helped resolve the initial confusion.
majormuss
I am confused with this equation I found online... It seems wrong to me, I need help.
My question is,why did the person who worked taht equation use a x^2 to rationalize the equation when the actual equation was an x^3??
http://tutorial.math.lamar.edu/Classes/Alg/Radicals_files/eq0081MP.gif
Because the fifth root of x^2*x^3=x^5 is x. How would you do it??
no my question is... why was x^2 used instead of x^3 to rationalize the denominator? my thinking is if x^2 is the denominator then why use x^3 to rationalize it?
Because x^2*x^3= x^5 as Dick said. The crucial point is that it is the fifth root that is to be rationalized. You have to multiply what ever power is necessary to get a fifth power inside the fifth root.
In general to rationalize the denominator of 1/\sqrt[n]{x^m} you need to multiply numerator and denominator by \sqrt[n]{x^{n-m}}. That way, in the denominator you will have \sqrt[n]{x^nx^{n-m}}= \sqrt[n]{x^n}= x.
I get it now thanks..
