Solve RC Circuit: Find Unknown Capacitor Value
The discussion revolves around finding the value of an unknown capacitor in an RC circuit with a specific configuration. The transfer function H(s) is stated to be independent of frequency, suggesting a constant ratio between V_out and V_in. One participant initially assumes this implies a DC condition, leading to a simplification of the circuit. However, another contributor clarifies that for H(s) to remain constant across frequencies, the reactances of the series and parallel components must cancel each other out, indicating a more complex relationship than initially perceived. The consensus is that the problem requires careful analysis of the impedances involved, and the presence of only one unknown may complicate achieving a solution.
dk702
The circuit is (10K ohm resistor in parallel with unknown Capacitor) which are in series with a 4.7k ohm resistor and a 0.1microF capacitor. V_in is applied over the entire circuit and V_out is taken over the 4.7k ohms and 0.1microF.
So here is the question.
In the circuit, H(s)=V_out(s)/V_in(s)(transfer function I imagine). It is a known that this ratio H(s) is independent of frequency. In other words, H(s) is simply a constant. Find The value of the unknown Capacitor in microfarads if all components are ideal.
My current thinking is that since H(s) is just a constant and not a function of frequency, there is no phase difference between V_in and V_0. I then assumed DC must be applied. If this is true then the Caps are charged and no current is flowing. Therefore, the circuit simplifies to the unknown Cap in series with the 0.1microF. Then by using Q=CV, I found unknown C=(V_out/(V_in-V_out))*0.1microF.
If you find any flaw in my thinking please point it out to me. Also if you want a picture of the circuit please email me at cq2120-forums@yahoo.com.
Where did you got the idea that H(s) is independent from frequency? It is clearly a function of the complex frequency s = σ + jω
It was part of the problem that was given to me.
The entire question was
"In the circuit, H(s)=V_out(s)/V_in(s). It is known that this ratio H(s) is independent of frequency. In other words. H(s) is simply a constant. Find the value of the uknown capacitor in microfarads if all components are ideal"
Well, that is quite different! Anyway, if it is said that the TF is independent of frequency, this means that it is a constant for any frequency and not only for DC. This would be trivial.
What happens is that the reactances of the series and the parallel capacitor cancel each other.
Let R1 and C1 be the parallel resistor and capacitor and R2 and C2 be the series elements.
The impedance of the series branch is Z2(s) = R2 + 1/(sC2).
The impedance of the parallel branch is Z1(s) =1/(1/ R1 + sC1).
The TF is H(s) = Z2(s)/(Z1(s) + Z2(s)).
For H(s) to be independent of frequency, the sum of all terms containing s in the numerator and in the denominator must be zero.
I don't think you will be able to equate those terms to zero with only one unknown.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 41 ·
  • · Replies 19 ·
