RC Circuit Transient Response Analysis
41 replies · 9K views · last reply
for t=24μs I get Vo as 6 x 0.1236 = 0.742V.
Where'd the 6 come from?
dudforreal said:
Isn't that Vth?
Perhaps we're looking at different problems? I thought you'd stated that Vo goes from 0V to 3.322V?
dudforreal said:
oh sorry...so it is 3.322 x 0.1236 = 0.411V.
That looks good. The numbers and calculation are good.
Gotta go catch some zZ's now. I'll check back in the morning (my morning, that is).
:zzz:
I think that my answer is wrong because when I used this equation on a different question with the same circuit with the voltage source being 4V, R1 = 1600, R = 2000 and C = 10n the answer I got was 0.798V but the correct answer is 1.4239V.
Good morning. (*YAWN*)
I took another look at the problem. A small correction is required to the time response formula.
This time the exponential is starting at zero and heading towards a final value that's equal to the Thevenin voltage of the resistor network. So the form is:
[tex]V_o(t) = V_{th} \left(1 - e^{-t/\tau} \right)[/tex]
Regarding your "different question with the same circuit", apply the above suggested formula and recheck your result -- also check to see if the time t1 to be plugged in is the same for both problems.
ok cool i got the answer. Now for the second part of the question with the switch between the resistor and the voltage source, my answer for the time before and after 0 as 0V and it is going to -5(7500/17500) = -2.143V.
Yes, that's what I see for that circuit.
