Reading datasheets to pick a comparator
2 replies · 2K views
akaliuseheal
Hello,
I've got a voltage comparator, well only on schematics, I need to chose one and I need some help interpreting datasheet. The datasheet I was looking at is of a lm393. My input voltage ranges from -7.8V to +7.8V. The datasheet says -0.3 to something. So it's not usable, right?
I was also looking at lm111 and here it is stated that input voltage can be from -15V to +15V which is great but I can't find information about output sink current.
You need to spend some time reading datasheets to learn the vocabulary.
The limitation is input voltage should lie between the power supply "rails"
That comparator can handle a dual supply of +&- 15 volts.
so you +&- 7.8 is well within that range.
You just have to give the comparatpr a +&- supply.
Can you Upload the schematic? Use the Upload button in the Edit window to Upload a PDF or JPEG copy. That will help us a lot in suggesting things for you to look for as you pick the comparator IC to us. Thanks. :smile:
