Real Image Optics: Selecting Correct Answer
A real image is defined as one that can be projected onto a screen, making option (d) the correct answer. The discussion involves eliminating incorrect options, specifically (b) and (c), which do not accurately describe a real image. The participant seeks clarification on whether (d) is equivalent to the definition of a real image. Ultimately, the consensus confirms that a real image is indeed represented by option (d). Understanding this concept is crucial for exam preparation in optics.
TitaniumX
Doing some practice problems to prepare for upcoming exam and ran across this:
A real image is
a. One in which light does not pass through the image point but appears to diverge from that point
b. One for which the magnification equal 1
c. An excellent image
d. An image that can be projected onto a screen
e. None of these
From what I learn, a real image is located in the plane of convergence for light that originate from a given object. I can easily eliminate (b) and (c). I'm just wondering if (d) could be an equivalent statement to a real image, or is it none of the above? Thanks
your thought processes are spot on.
That's good to hear. So can you (or someone) help lead my though process to the correct conclusion?
you have the answer... a real image is (d)
Thanks! Just making sure :)
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
