Recurrence Relations, finding f(n)
ramenmeal
Find f(n) when n = 2^k, where f satisfies the recurrence realtion f(n) = f(n/2) +1 with f(1) = 1
f(n) = a*f(n/b) + c
when n = b^k, where k is a positive integer,
f(n) = C1n^(log a base b) + C2
C1 = f(1) +c/( a-1) and C2 = -c/ (a-1)
keep in mind i may be trying to use the wrong equation...
a =1, b = 2, c = 1
then C1 = 1+ 1/0 and C2 = -1/0
i'm not sure what i can do from here... c1 and c2 both include undefined #'s
perhaps I'm not even approaching the problem correctly?
Hi,
Now I am not sure if I understood it correctly, but it seems to be much simpler:
if n = 2^k and f(n) = f(n/2) + 1
f(n) = f(2^k) = f(2^(k-1)) + 1 = ... = f(2^(k-j)) + j
Now, the answer should be obvious.
I would start by calculating some values. f(20)= f(1)= 1, f(21)= f(2)= f(1)+ 1= 2, f(22)= f(4)= f(2)+ 1= 3, f(23)= f(8)= f(4)+1= 4, f(24)= f(16)= f(8)+ 1= 5. Looks obvious to me. Of course, you still have to prove that obvious "guess". Proof by induction should work.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
