- 2,163
- 191
Reduced mass can be defined as
##μ= \frac {m_1m_2} {m_1+m_2}## For ##m_1>>m_2##, ##μ_2≈m_2##
How can we prove this ?
But also there's ##m_1m_2## ? Our teacher used the binomial expansion. I don't think your arpproach is true.How can we do it by using it ?mfig said:If ##m_1>>m_2##, then how would you approximate ##m_1 + m_2##?
For example, say ##m_1=10^7## and ##m_2=1##. What, approximately, is ##m_1 + m_2##?
Okay I did it.mfig said:I don't understand why you say, "But also..." in response to a question. What is your answer to the question I asked?
As I said there's ##m_1m_2## part. We can just consider the denominator part.mfig said:I don't understand why you say, "But also..." in response to a question. What is your answer to the question I asked?
And I am saying that you cannot just say $$m_1m_2/m_1=m_2$$ Thats mathematically incorrect. I can understand you don't worry about that, but it seems you didnt understand me. Even if we try to take it as a limit we get $$ylim(x→∞)=x/(x+y)$$ and then we cannot put just infinity since ##(∞/∞)## is uncertain. So you can do either L' Hospital's Rule or we can write as $$ylim(x→∞)x/(x(1+y/x))=ylim(x→∞)1/(1+y/x)=ylim(x→∞)1/(1+0)=y$$ which that's what I wrote.mfig said:"As I said there's m1m2" role="presentation">m1m2 part. We can just consider the denominator part."
I was going to walk you through it (Step1, then Step 2, etc.). I guess you misunderstood what was happening, which is why you didn't answer my simple question. Of course step 2 involves cancelling...
Anyway, glad you got it.
Arman777 said:Reduced mass can be defined as
I don't get this.Arman777 said:And I am saying that you cannot just say $$m_1m_2/m_1=m_2$$ Thats mathematically incorrect.
The second equality is incorrect. It should beArman777 said:Okay I did it.
$$μ=\frac {m_1m_2} {m_1+m_2}=m_2(\frac {1} {1+m_2/m_1})$$ then
$$m_2(1+m_2/m_1)^{-1}=m_2(1-m_2/m_1)$$ and then we can say $$m_2/m_1≈0$$ since, ##m_1>>m_2 → 1>> m_2/m_1## Hence $$μ≈m_2$$
Its not incorret I just put ##=## instead of ##≈##.DrClaude said:he second equality is incorrect. It should be
Clearly any of you don't know math.I already explained the case. If you don't get it learn the math and limits.DrClaude said:I don't see the difference between what you did and using m1+m2≈m1m1+m2≈m1m_1 + m_2 \approx m_1 to write
DrClaude said:Also, I would say that dropping terms of the order O(m2/m1)O(m2/m1)O(m_2/m_1) is not the same as taking the limit m2/m1→0m2/m1→0m_2/m_1 \rightarrow 0.
Arman777 said:Clearly any of you don't know math.
DrClaude said:I don't get this.
$$m_2(1+m_2/m_1)^{-1} \approx m_2(1-m_2/m_1)$$
I don't see the difference between what you did and using ##m_1 + m_2 \approx m_1## to write
\frac{m_1 m_2}{m_1 + m_2} \approx \frac{m_1 m_2}{m_1}
One the approximation is made, normal math takes over and one can write
\frac{m_1 m_2}{m_1} = m_2
Vanadium 50 said:Do you think this is going to help? Likewise, do you think YELLING at the people who are trying to help you is a good strategy?
Arman777 said:But also there's m1m2m1m2m_1m_2 ?
Arman777 said:As I said there's m1m2m1m2m_1m_2 part. We can just consider the denominator part.
Arman777 said:And I am saying that you cannot just say $$m_1m_2/m_1=m_2$$ Thats mathematically incorrect. I can understand you don't worry about that, but it seems you didnt understand me. Even if we try to take it as a limit we get $$ylim(x→∞)=x/(x+y)$$ and then we cannot put just infinity since ##(∞/∞)## is uncertain. So you can do either L' Hospital's Rule or we can write as $$ylim(x→∞)x/(x(1+y/x))=ylim(x→∞)1/(1+y/x)=ylim(x→∞)1/(1+0)=y$$ which that's what I wrote.
You started to convo with what is the value of ##m_1+m_2## its not hard to see what you are going to do.
DrClaude wasn't taking a limit, so why would he use L'Hospital's rule?Arman777 said:Is this looks like L'Hosptial ? No
People read what you wrote and don't agree with you. There's nothing mathematically wrong with the method mfig and DrClaude used. Neither was taking a limit, so your claim that they're overlooking an indeterminate form doesn't apply. As DrClaude noted earlier, neglecting higher order terms isn't the same as taking a limit.I was not yelling. I was trying make a point there. I wrote the same things during the conversation and non of you tried to read it. And still you guys are posting stuff just to say that I was wrong and, I am not wrong.. Its so sad to see such things in people that when someone makes a mistake no one have guts to accept it.
I asked my classical mechanic prof and he said there's no such approximation as you guys said.vela said:DrClaude wasn't taking a limit, so why would he use L'Hospital's rule?People read what you wrote and don't agree with you. There's nothing mathematically wrong with the method mfig and DrClaude used. Neither was taking a limit, so your claim that they're overlooking an indeterminate form doesn't apply. As DrClaude noted earlier, neglecting higher order terms isn't the same as taking a limit.
To put it another way, you seem to be claiming that you can't say
$$\frac x{1000001} = \frac x{1000000+1} \cong \frac x{1000000}$$ without knowing what the value of ##x## is, which is ridiculous. Just as dividing by 1000000 will give you close to the same answer as dividing by 1000001 because ##1000000 \gg 1## regardless of the value of ##x##, dividing by ##m_1## will give you approximately the same answer as dividing by ##m_1+m_2## when ##m_1 \gg m_2## whether or not ##m_1## appears in the numerator.
I'm very confused about this thread. Apart from writing equals instead of approximately equals, you did this in #5.Arman777 said:He said we should use binomial approximation. For $$m_2/m_1<<1$$
