Find GCD from Prime Factorizations: Reducing Fractions
  • Thread starter Thread starter Holocene
    Fractions
The greatest common divisor (GCD) can be derived from the prime factorizations of the numerator and denominator by identifying and multiplying the lowest powers of common prime factors. In the example of 48 and 150, the prime factorizations reveal shared factors of 2 and 3. By selecting pairs of identical prime factors, the GCD can be calculated efficiently. This method is straightforward and effective for determining the GCD from prime factorizations. Understanding this process simplifies reducing fractions.
Holocene
Is there any way to derive the greatest common divisor from the prime factorizations of the numerator and denominator?
For instance:
\displaystyle{\frac{48}{150} = \frac{ 2 * 2 * 2 * 2 * 3}{2 * 3 * 5 * 5}}
The GCD = 6 in this example, but is there any way to determine that from the prime factorizations alone?
Mathematics news on Phys.org
Yes, that's the easiest (if not fastest) way. Just choose pairs of identical prime factors until none are left that match, then multiply the primes together.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
