Reflection and refraction with equal refractive indices?
When two mediums have the same refractive indices, the Fresnel equations suggest that radiation should be fully transmitted, yet reflections occur due to microscopic imperfections like cracks in glass. These imperfections can create areas where the refractive index changes, such as when air or vacuum fills the cracks, leading to reflection. In ideal conditions, two identical crystals in perfect contact would theoretically have no visible boundary and no reflection. However, practical scenarios often involve geometrical factors that cause some light perturbation at the interface. This principle is illustrated by using a crystalline powder in glass, where the powder appears opaque until a liquid with the same refractive index is introduced, making it transparent.
Hypatio
The Fresnel equations indicate that radiation will be 100% transmitted if two mediums have the same refractive indices. If that is true, then whey is there so much reflection off of, for instance, cracks in glass? Is this because there is a microscopic vacancy where the index of refraction becomes that of a vacuum or air, which is ~1?
Similarly, if there are two crystals with equal properties in near-perfect contact, will the boundary between the two be invisible?
Science news on Phys.org
If you are talking about an ideal situation then there would be no discontinuity - hence no reflection.
If you are talking about a practical situation then you would need to specify the geometry of the interface (spacing / angle etc) but you would expect some perturbation of the ray at the interface.
I think it is the filling of the cracks with gas or vacuum of other index of refraction. You can demonstrate this by bringing a crystalline powder (sugar, salt or the like) in a glas. It will appear white and not transparent. However, if you fill in a liquid with the same index of refraction as the powder, the powder will appear transparent. In fact, this is used to determine the index of refraction in mineralogy.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
