Reflection Coefficient: Steps 4 to 5 Explained by Drforbin
The discussion focuses on understanding the transition from step 4 to step 5 in calculating reflective coefficients in transmission lines. Participants suggest clearing fractions by using the least common denominator and rearranging terms to isolate V+ and V- on opposite sides of the equation. The process involves cross-multiplying and canceling like terms, ultimately leading to the correct expression. Drforbin expresses gratitude for the assistance and shares that they have made progress on the problem. The thread highlights the importance of collaborative learning in complex mathematical concepts.
merlyn
Hi all, Great forum.
I really don't know if this is the proper place for this,
so if it is not please forgive me.
I have been researching reflective coefficients in transmission lines. I understand everything except steps 4 -> 5.
Perhaps it is a lacking in my math skills but could someone show me the steps in getting from 4 to equation 5.
thank you.
Drforbin.
Mathematics news on Phys.org
Are you acquainted with the technique of clearing fractions from an equation by using the least common denominator of all the terms?
(This is really an algebra question, so I've moved this thread to General Math.)
You mean rationalizing the fraction ?
thank you.
Drforbin.
Collect all the V+ terms on one side and all the V- terms on the other side of the equation. Then pull the V+ and V- terms out by clearing the fractions like jtbell said, and at that point all that is left to do is cross multiply and cancel your like terms. You'll need to pull out a negative so you end up with the Zl - Zo on top and the Zl + Zo on the bottom.
Hi guys...I actually did this last night.
I think I have it. Here are my notes. I hope this helps anyone else.
Great Thanks to you all again.
This is a great resource for people trying to learn.
Something in short supply these days. At least in the U.S.
Drforbin.
I forgot last step.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
