Reflections at the source point of a transmission line
  • Context: Graduate
  • Thread starter Thread starter miner_tom
The discussion focuses on the use of the Smith chart to analyze the input impedance of a transmission line affected by load reflections. It establishes that reflections occur only when there is an impedance mismatch, even if the source impedance matches the characteristic impedance (Zo) of the line. The conversation highlights that a matched source will absorb reflected waves without generating further reflections, and emphasizes the importance of precise matching for accurate measurements. The complexities of multiple reflections and their mathematical implications are acknowledged but deemed too intricate for general discussion.
  • Understanding of Smith charts for impedance matching
  • Knowledge of transmission line theory and characteristic impedance (Zo)
  • Familiarity with wave propagation and reflection principles
  • Experience with measuring instruments for RF applications
  • Study advanced Smith chart applications for complex impedance matching
  • Explore transmission line reflection coefficients and their calculations
  • Learn about standing wave ratios (SWR) and their significance in RF systems
  • Investigate the effects of multiple reflections in transmission lines
Electrical engineers, RF engineers, and students studying transmission line theory who seek to deepen their understanding of impedance matching and wave behavior in transmission lines.
miner_tom
TL;DR
Is there always a reflection from the source after a reflection from the load?
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it appears to the source is not necessarily equal to the characteristic impedance of the transmission line, will there be a reflection even if the original source impedance is equal to Zo
Source: https://www.physicsforums.com/forums/electromagnetism.302/post-thread
miner_tom said:
The impedance of this wave as it appears to the source is not necessarily equal to the characteristic impedance of the transmission line, will there be a reflection even if the original source impedance is equal to Zo.
Reflections only occur where there is an impedance mismatch.
If the source is matched to the line, then there will be no reflection at the line input port. If there is a discontinuity somewhere up the line, there will be a reflection from there. When that reflected wave returns to the source, it will be absorbed in the matched impedance, without another reflection.
The voltage and current of the wave travelling up the line has a ratio fixed by the characteristic impedance of the line, v / i = Zo. The same is true for the reflected wave travelling back from a reflection. At any point on the line, the sum of the voltages and currents of the two waves travelling in different directions will make a standing wave.
Exactly. Mr Smith says nothing about multiple reflections from both ends; the maths would be too hard and specific to every particular situation. Setting up a measurement has to involve matching the source to a very high standard and that's the only way you can measure what's going on at the other end.
[Edit: I'd reconsider that statement. I once had a colleague (way back) who could probably have done it. Bob Thoday - RIP - was very clever.)]
  • · Replies 21 ·
  • · Replies 18 ·
