Relationship between CFM vs PSI
The discussion centers on the relationship between airflow (CFM) and pressure (PSI) in a scenario involving air collected by a scoop and directed through a cavity. Increasing the collection area of the scoop leads to higher pressure readings, raising questions about the correlation between pressure increase and airflow volume. It is clarified that while pressure and velocity are related, the total pressure does not depend on duct geometry, and a restriction can cause velocity pressure to rise while static pressure falls. The use of Bernoulli's principle is suggested to analyze the pressure differential and flow rates, emphasizing the need for accurate measurement tools to assess airflow changes effectively. The conversation highlights the complexity of airflow dynamics and the importance of precise measurement techniques in understanding these relationships.
xr3tf
I have been "googling" to find the relationship between the above, and the answer has mostly been a resounding "NO".
Maybe my question is not "CFM" vs "PSI", but that is the only way I know how to descibe my question. I will explain the scenario:
I have air flowing at a constant speed (over the body of a car) which is being "collected" with a scoop and then channelled into a cavity with an open end, so the air flows through it. At the back of the cavity, I measure the "pressure" of the air by means of a Magnehelic meter which gives pressure in "inches of water" as the air passes over / through my measuring point back to the athmosphere.
If I increase the collection area of the scoop, I get more air being collected still at the same constant speed and the pressure measured increases as more air flows through the collection point.
My question is this: If the pressure as measured at the back of the cavity increases by 20%, what relationship does the "volume of air" collected by the two different scoops have to this 20% increase in velocity pressure? Is this a 1:1 relationship, or is it something different?
I am trying to equate that a 20% pressure increase as measured by my meter is as a result of a x% increased in air flow.
Your meter is screwed up if this is happening. A pressure probe should not depend on the volume of air it is sampling.
You can go from pressure to volumetric flow rate in certain situations, but not without working probes.
Thanks for the reply.
My meter is unfortunately not faulty.
Maybe I did not explain my scenario enough. With the amount of air being "scooped in" and being directed through an area that is smaller than the area if the scoop, ie a restriction, surely there must be some kind of pressure build-up at the exit of this restriction? Air speed through the smaller area probably increases which then leads to a lower pressure along the inside of the restriction etc, but that is not what the meter tells me at the exit.
I am not a mechanical engineer by any means - I simply have a problem that that should have a logical solution (I hope)
The ratio of that intake area to outlet area definitely makes a difference assuming there are no processes going on in between them such as combustion. Generally, as inlet area/outlet area gets larger, the pressure you measure should go up.
If you measure the pressure at the inlet and the outlet, you will have a pressure differential that can be used with Bernoulli's equation which relates pressure and velocity. You then have two unknowns, inlet and outlet velocity. You can relate those two using conservation of mass which says Velocity*Area is constant from one point to another in the flow (in certain cases, this being one of them).
There you have two equations and two unknowns. It is fairly simple to solve. You can then easily get volumetric flow rate from that outlet velocity and the area, which you know.
You're looking for Bernoulli's principle (and your logic is pretty close to correct): http://en.wikipedia.org/wiki/Bernoulli's_principle
In short, the total pressure of your airstream doesn't depend on the geometry of the duct, but a restriction will cause the velocity pressure to rise and the static pressure to fall.
static pressure + velocity pressure = total pressure
So which are you measuring? What does the pressure gauge installation look like?
Having thought about this, I probably need a very sensitive flow meter to determine whether I have increased airflow with the bigger scoop.
I have fabricated a "matrix" of collection points that cover the largest portion of the cross section of the duct, in order to reduce eratic readings on the pressure gauge due to turbulance as the air enters the duct. The matrix allows prssures to be measured at the collection points, whilst air also flow through open areas in the matrix.
I use a Dwyer Magnehelic gauge for my measurement.
I tried using a brushless DC motor that was mounted in the airstream before as a means of measurement - I then measured the output voltage generated by the motor to compare, but it use to overspin very quickly once the scoop area was increased.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
