Relationship between pressure and thermal conductivity
The discussion focuses on deriving an equation that connects thermal conductivity to pressure using the kinetic theory of gases. The participant initially assumed thermal conductivity is independent of pressure but later explores its dependence on temperature gradients. Key equations referenced include the ideal gas law (PV=nRT) and the heat flow equation (q = lambda * grad T). The participant seeks clarification on the derivation found in "Transport Phenomena" by Bird, Stewart, and Lightfoot, specifically regarding its page number and content.
  • Kinetic theory of gases
  • Understanding of thermal conductivity
  • Familiarity with the ideal gas law (PV=nRT)
  • Basic principles of heat transfer and temperature gradients
  • Study the derivation of thermal conductivity in "Transport Phenomena" by Bird, Stewart, and Lightfoot
  • Research the relationship between pressure and temperature in gases
  • Learn about the mathematical modeling of heat transfer in materials
  • Explore advanced concepts in kinetic theory and its applications in thermodynamics
Students and professionals in physics and engineering, particularly those focusing on thermodynamics, heat transfer, and material science.
jhartc90
I would like to derive an equation that relates the thermal conductivity to the pressure using the kinetic theory of gases. However, I assumed that thermal conductivity was independent of pressure.
I know that P = 2N/3V (1/2mv^2)
Also:
I believe that thermal conductivity is dependent on the temperature gradient in a material.
I know the flow of heat is proprotional to the temp. gradient.
So:
q = lambda * (grad T)
I cannot attempt this until I understand how the two are related. I know that the thermal conductivity can be related to the temperature gradient. I guess temperature is dependent on pressure. But I am fairly lost in how to relate the two.
Could I used the ideal gas law?
PV=nRT
grad(P)V = nR grad(T)
so grad(T) = grad(P) V / nR
q = lambda * grad(T)
lambda = q / grad (t)
Then
lambda = q / grad(P) V / nR
There is a derivation of this in Transport Phenomena by Bird, Stewart, and Lightfoot.
what page in the book is the derivation of this on? All I see is a figure (Fig. 9.2-1)
  • · Replies 18 ·
