Relationship of diffrent parameters of Gas turbine
The discussion revolves around understanding the relationships between various parameters of gas turbines, specifically focusing on the Saturn 1100 and Centaur 4500 models. Participants inquire about calculating specific performance metrics such as specific fuel consumption (SFC), heat rate, and the effects of lower heating value (LHV) on SFC, as well as seeking resources for gas turbine theory.
  • Technical explanation, Homework-related, Debate/contested
  • One participant asks about the relationship between compressor discharge pressure and fuel flow.
  • Another participant notes that accurate calculations of the parameters require detailed design information about the turbines and suggests checking with manufacturers for performance data.
  • A suggestion is made to refer to ASME PTC 22 for comprehensive information on testing gas turbines.
  • Several participants request links to download ASME PTC 22 for free.
  • There is a query regarding the calculation of mechanical torque in gas turbines.
  • Another participant seeks clarification on how to calculate SFC and heat rate, along with water injection (WI) metrics.
Participants express a need for more information and resources, but there is no consensus on the specific calculations or relationships discussed. Multiple competing views on how to access information and perform calculations exist.
Participants mention the need for specific design information and performance data, indicating that assumptions about the turbines' characteristics are necessary for accurate calculations. There are unresolved requests for free resources and specific calculation methods.
Individuals interested in gas turbine performance, engineering students, and professionals seeking to understand gas turbine metrics and testing standards.
Hamadsultan
Hi friends;
I have Saturn 1100 and centaur 4500 two shaft gas turbines from solar INc. I want to know that what relationship of following parameters
1. Compressor discharge pressure and fuel flow
2. How i calculate the SFC?
3. What effect of LHV on SFC?
4. How i calculate the Heat rate?
If anyone have a link which contains the general twoshaft gas turbine theory and examples please send me i am very thankful.
Best regards
You can't calculate those parameters accurately unless you know a lot of information about the design of the turbines. Information about the performance and SFC should be available from the manfacturers. http://mysolar.cat.com/
Get hold of a copy of ASME PTC 22 tells you all you need to know about testing gas turbines.
Hi Jobreg
Can u send ne a link where from i download ASME PTC22 free.
Thanks
Best regards
Hi friends;
Please send me a link where from i can download ASME PTC 22 free
secondly anyone know how to calculate SFC and HR of gas turbine and as well as WI
Thanking U i will remain
how to calculate mechanical torque of a gas turbine ?
  • · Replies 23 ·
