Comparing Forces in Different Reference Frames: Impact on Time and Magnitude
  • Thread starter Thread starter Yayness
    Force Relative
This discussion centers on the relativistic dynamics of force as experienced in different reference frames, specifically frames A and B. It establishes that the force felt by an object in one frame may differ from the force applied by another frame due to relativistic effects such as time dilation and the relative velocity between the frames. The formula derived, a = (F/m)(1 - (v²/c²))^(3/2), illustrates how acceleration is affected by these factors, leading to different perceived forces in each frame. The conversation emphasizes the importance of understanding proper force in the context of relativity.
  • Understanding of basic concepts in relativity, including time dilation and length contraction.
  • Familiarity with Newton's laws of motion and the concept of force.
  • Knowledge of inertial reference frames and their significance in physics.
  • Basic mathematical skills to manipulate equations involving forces and accelerations.
  • Study the derivation and implications of the formula a = (F/m)(1 - (v²/c²))^(3/2).
  • Learn about proper force and its role in relativistic dynamics.
  • Explore the concept of relativistic mass and its impact on force calculations.
  • Investigate the relationship between force, acceleration, and reference frames in more complex scenarios.
Students and professionals in physics, particularly those focused on relativity, dynamics, and the mathematical foundations of force in different reference frames.
Yayness
One reference frame A uses a force F on another reference frame B.
Both A and B counts the time it takes before A stops using the force F on B. They end up with different results.
Will B feel a different value of the force coming from A?
Will F*t be different in the two reference frames? (Where t is the time it takes before A stops using the force.)
Will B use the same force on A as the force A uses on B?
Hi Yayness! :smile:
Tell us what you think, and then we'll comment. :wink:
Reference frames are coordinate systems. They are mathematical constructs, not physical objects. How do you apply a force to a mathematical object like a coordinate system?
I am quite new to relativity, but I have read about it and tried to derive different formulas. (So far, I have derived formulas for length contradiction, time dilation and velocity addition for instance.)
I read about relativity on the internet and I saw this formula:
a=\frac{F}{m}(1-\frac{v^2}{c^2})^{\frac{3}{2}}
Where a is the acceleration of an object, observed by an inertial frame. F is the force used on the object (by the inertial frame, I believe), m is the rest mass of the object, and v is the velocity relative to the inertial frame.
I tried to derive this formula, and so far, I have managed to derive that
a=(1-\frac{v^2}{c^2}) a_0
where a0 is the acceleration felt by the accelerating object, and a is the acceleration observed by the inertial frame.
Relative to itself, the object is at rest, so the force it feels does only depend on its rest mass and the acceleration it feels. If we let F0 be the force it feels, then
F0=a0m
If I put that in the formula I derived, I get that:
a=\frac{F_0}{m}(1-\frac{v^2}{c^2})
So if the formula I am trying to derive is correct, it means that
F_0=\sqrt{1-\frac{v^2}{c^2}} F
where F is the force the inertial frame uses on the object, and F0 is the force the object feels.
Is this correct, and if so, why?
I mean two objects where one of them is at rest in one reference frame, and the other one is at rest in another reference frame.
If one object uses a force on the other one, will the value of this force be different in the two reference frames?
These are all good questions that highlight the problem of what exactly is "force" in relativistic dynamics.
Have a think about what proper force is.
  • · Replies 87 ·
  • · Replies 167 ·
  • · Replies 33 ·
  • · Replies 30 ·
Undergrad EPR revisited
  • · Replies 29 ·
  • · Replies 22 ·
  • · Replies 20 ·
  • · Replies 144 ·
9K
  • · Replies 16 ·
