Speed of Proton at 750keV Kinetic Energy
dancergirlie
What is the speed of a proton after being accelerated to a kinetic energy of 750keV?
E=K+E0
E0=mc^2
K=(gamma-1)mc^2
gamma=1/(sqroot(1-v^2/c^2))
Alright, so to find the speed, I used the equation:
K=(gamma-1)mc^2
which i simplified to:
1/(gamma-1)=mc^2/K
I converted K into joules which is equal to 1.202E-13 J
and what I ended up getting was that
sqroot(1-v^2/c^2) - 1=1250.42
but if i continue on with that I will need to take the square root of a negative number because i will bring v^2/c^2 to the right side and then I would have to do 1-1250.42 and take the square root of that which is undefined. Any help would be great!
Do yourself a favor and use symbols throughout your derivation. Plug in at the very end. It would be easier to trace your error(s) if you did. As it is, I cannot figure out what that 1250.42 means or where it came from. If you have gotten to the stage of special relativity you should be able to handle expressions symbolically. Doing so enables you to find your mistakes much more easily through dimensional analysis.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
