Relativity: Noob Ques. - Why Do People on Earth Seem Stationary?
  • Context: Undergrad
  • Thread starter Thread starter willm78
    Noob Relativity
The discussion revolves around the twin paradox in the context of relativity, specifically addressing why the twin on Earth is treated as stationary while the traveling astronaut experiences time dilation. Participants explore the implications of relative velocity, acceleration, and the effects of gravity on aging, as well as the conceptual challenges posed by these ideas.
  • Some participants note that velocity is relative to a reference frame, and the astronaut's frame is non-inertial due to acceleration, affecting the application of time dilation formulas.
  • Others argue that the astronaut's experience of acceleration distinguishes their aging from that of the twin on Earth, leading to asymmetrical aging outcomes.
  • One participant questions whether the twin on Earth experiences constant acceleration due to gravity, suggesting this might complicate the comparison with the astronaut's experience.
  • Another participant mentions that the traditional formulation of the twin paradox simplifies the scenario by treating the Earth-bound twin as stationary, potentially to create a clearer mental image.
  • Some participants highlight that including gravity requires a consideration of General Relativity, as the typical twin scenario often assumes no gravitational effects.
  • A later reply discusses the ambiguity of the term "acceleration" in General Relativity, differentiating between proper acceleration and coordinate acceleration.
Participants express varying views on the implications of acceleration and gravity in the twin paradox scenario, indicating that multiple competing perspectives remain without a clear consensus on the best interpretation.
Participants note that the effects of gravity on the Earth-bound twin are relatively small compared to the time dilation experienced by the traveling twin, but this remains an unresolved aspect of the discussion.
This discussion may be of interest to those exploring concepts in relativity, particularly the twin paradox, and the effects of acceleration and gravity on time dilation.
willm78
Something sparked my interest yesterday, so I started watching videos and reading about relativity. (This seems to happen every year or so.) I get hung up on the same thing every time!
Many discussions I've seen use the example of an astronaut that takes a trip into space for 10 years or so and then comes back to see that his twin has aged significantly more than he has. If velocity is relative to each observer (correct me if I'm wrong), why do these examples always treat the people on Earth as being stationary? To the astronaut, wouldn't it seem as though his twin on Earth was the one who had been traveling at a high velocity over the course of the previous 10 years, and thus be the one that has aged slower?
My brain is about to explode. Please help!
Hi willm78, welcome to PF!
Velocity is relative to a reference frame. The reference frame of the astronaut is non inertial, so the time dilation formula doesn't apply.
Ahh ok, so it has something to do with the fact that the astronaut experience some significant acceleration over the period of his travel?
Still not sure how this affects his frame of reference though.
Well, you can always distinguish which twin is accelerating, even though their motion is relative. So you can always know which one aged more, the situation is not symetrical. Also, you could consider either one to be at rest, that doesn't matter.
In more adequate terms their paths through spacetime have different proper times.
willm78 said:
Ahh ok, so it has something to do with the fact that the astronaut experience some significant acceleration over the period of his travel?.
Yes, exactly.
It means that the laws of physics don't work normally in the astronaut's frame. Consider Newton's second law, the astronaut experiences a force but does not accelerate. That isn't normal. Similarly with time dilation: the normal formulas don't work in the astronaut's frame.
But to the twin on earth, doesn't the effect of gravity make it seem as though he's constantly accelerating? While the astronaut, once he reaches cruising speed and assuming he is traveling in a straight line, does not feel he's moving?
Maybe I'm confusing the local effects of gravity on Earth with some global laws of physics?
No, seems a very good point to me: the twin on Earth is indeed accelerated and this has the same qualitative effects as for the astronaut. It's just that the effect on Earth is quite small because Earth gravity is only 1g. You could get rid of it by having the earth-based twin stay in the ISS the whole time instead, but of course that wouldn't significantly change how fast he ages.
I'm not sure but it sounds as if the traditional formulation of the twin paradox was meant to have a simple mental picture? therefore the twin staying at earth.
I guess that sticks more than having the whole situation out in empty space. Just a thought.
The remark about the twin on Earth having non-zero proper acceleration is correct of course.
Typically the twins scenario has no gravity. Often it even just says "home" rather than "earth" just to avoid implying any gravity.
If you really want to include gravity then you need to use General Relativity.
Willm, in case you know enough relativity, you could check in Schutz, the section called "The twin paradox dissected" for further clarification. It's on page 25 in the second edition.
thanks Cruz, I'll check that out.
Side note, I just read that an inertial observer, in the context of GR, means no force is acting upon him except gravity. Am I interpreting this correctly in that GR differentiates gravity from acceleration?
willm78 said:
I get hung up on the same thing every time!...
We've all been there, and your brain won't really explode... it just feels that way. :)
Seriously, kidding aside, the twin paradox in which two twins start at the same place, move along different paths for a while, then rejoin and compare their ages is surprisingly difficult. There's a really good FAQ here, and you should read it.
But before you take on the twin paradox, you might be better off working through the simpler problem of two astronauts moving relative to one other - constant speed, no acceleration, no turning around, no gravity, no separation and reunion. How is it possible that both see the other as being time-dilated? How can A be slower than B and also B be slower than A? Get clear on this and you'll be able to take on the twin paradox without fear of cerebral detonation.
Nugatory thanks for pointing me to the FAQ. I've started to read it, and already I can see it's going to answer my questions. Can you provide a reference link for the other example?
The word "acceleration" is ambiguous. Sometime it means coordinate acceleration, which is a change in the speed, relative to some other object, of the accelerating object. Other times it means proper acceleration, which is what an accelerometer attached to the object registers.
In general relativity, "acceleration" without any qualifying adjective usually means proper acceleration. However the acceleration of an object freely falling in a gravitational field is coordinate acceleration - the falling object is accelerating relative to an observer on the surface of the earth, but an accelerometer attached to the object will say that no force is acting on the object until its free fall is interrupted by hitting the ground.
By "your other question" do you mean why the stay-at-home twin doesn't find himself younger because he's subject to the Earth's gravity?
The stay-at-home twin does end up younger than a hypothetical third (should we calling this the "triplet paradox"?:) ) twin who starts out the same age but spends the entire time floating in free fall in empty space far away from any massive object.
It just so happens that you if grovel through the math, you will find that for reasonable earth-like gravitational fields this effect is small compared with the effect of the traveling twin's journey. Thus, despite the gravitational time dilation, the earth-bound twin ends up less aged than than thevtravelling twin.
Gravity doesn't cause proper acceleration (a falling accellerometer measures zero), just coordinate acceleration (change in velocity in non-inertial frames of reference). That's why in GR local gravity is interpreted as a coordinate effect. Check the video below for a comparison of the two models of gravity.
  • · Replies 42 ·
  • · Replies 20 ·
  • · Replies 35 ·
  • · Replies 53 ·
  • · Replies 36 ·
