Relativity Question with Lorentz tranformations
The discussion revolves around a relativity problem involving Lorentz transformations, where observer O sees two light flashes at different times and locations. The participant successfully calculated the time interval t' as 1.73 microseconds but encountered discrepancies when calculating the distance x', consistently arriving at 2.34 km instead of the textbook's -1.90 km. Concerns were raised about the textbook's answers, suggesting they might be incorrect due to inconsistencies in the spacetime interval calculations. The calculations confirmed that both observers agree on the spacetime interval, which indicates the textbook's values may be erroneous. The conversation highlights the importance of verifying textbook solutions against fundamental principles of relativity.
sr6622
Observer O sees a red flash of light at the origin at t=0 and a blue flash of light at x = 3.26km at a time t = 7.63 \mu seconds. What are the distance and the time interval between the flasheds according to ovserver O', who moes relative to O in the direction of increasing x with a speed of 0.625c? Assume that the origins of the two coordinate systems line up at t = t' = 0.
x' = \gamma(x - ut)
t' = \gammat - (u/c^2)x
I solved for t' and got the answer 1.73 \museconds. From the back of my textbook, this seems to be the correct answer.
When I put x = 3.26km into the first equation above, I always get the answer to be 2.34 km. The answer fromt the back of my textbook says \Delta x' = -1.90 km.
I'm wondering what I'm doing wrong...
Just to make it a little clearer, this equation should be written
t' = \gamma[t - (u/c^2)x]
Are you sure you have the answer for the right problem? (I'm hoping they didn't change the numbers in the problem between editions and forget to change the answers -- I've seen that a little too often...)
Something about their answer doesn't seem right because the spacetime interval should be
(delta-s)^2 = (c delta-t)^2 - (delta-x)^2 = (c delta-t')^2 - (delta-x')^2 ,
which doesn't happen with their values.
I have \gamma = 1.2810 . I guess we're agreed that x' = 0 , t' = 0 for the red flash. I also agree with you that, for the blue flash,
x' = (1.281) [ (3.26 km) - (0.625)(300,000 km/sec)(7.63e^-6 sec) ] = 2.343 km .
However, I get
t' = (1.281) [ (7.63e^-6) - (0.625)(3.26 km/300,000 km/sec) ]
= 1.074e^-6 sec or
ct' = 0.322 km.
In O's frame,
(delta-s)^ 2 = [ (300,000 km/sec)(7.63e^-6 - 0 sec) ]^2 - ( 3.26 - 0 km )^2
= -5.388 km^2
A negative space-time separation makes sense because the light-travel time in O's frame from the location of the blue flash is 3.26 km/300,000 km/sec = 10.9 microseconds, which is longer than the time separation between the flashes.
In O' 's frame,
(delta-s)^ 2 = [ (300,000 km/sec)(1.074e^-6 - 0 sec) ]^2 - ( 2.343 - 0 km )^2
= -5.386 km^2 (the difference is likely "round-off" error) .
You do not get this value with the book's answers. Unless we're missing some point about the problem description, I find their answer suspect.
(a) The polarisation pattern is elliptical with maximum (1,1) and minimum (-1,-1), and anticlockwise in direction. (b) I know the solution is a quarter-wave plate oriented π/4, and half-wave plate at π/16, but don't understand how to reach there. I've obtained the polarisation vector (cos π/8, isin π/8) so far. I can't find much online guidance or textbook material working through this topic, so I'd appreciate any help I can get. Also, if anyone could let me know where I can get more...
  • · Replies 53 ·
  • · Replies 24 ·
  • · Replies 35 ·
