Remaining Fraction of Particle Beam After CERN Use
The discussion focuses on the remaining fraction of a particle beam after its use in the Large Hadron Collider (LHC) at CERN. It is established that approximately 1/2 to 1/3 of the initial protons remain in the beam at the end of a typical operational period, which can last 24 hours. The LHC operates continuously, and beams are often dumped for safety reasons or when refilling leads to higher collision rates. The LHC primarily collides protons with protons, not antiprotons, and starts with around 2 billion collisions per second in the ATLAS and CMS experiments.
  • Understanding of particle physics concepts, specifically proton collisions.
  • Familiarity with the operational mechanics of the Large Hadron Collider (LHC).
  • Knowledge of collision rates and their impact on particle beam integrity.
  • Basic grasp of safety protocols in high-energy physics experiments.
  • Research the operational protocols of the LHC, focusing on beam dumping procedures.
  • Learn about the collision dynamics in proton-proton interactions at high energies.
  • Investigate the role of safety measures in particle accelerators like the LHC.
  • Explore the differences between various CERN accelerators and their specific applications.
Particle physicists, researchers in high-energy physics, and anyone interested in the operational aspects of the LHC and particle beam dynamics.
Spinnor
When Cern is done with a particle beam, what fraction of a typical beam bunch is left having not scattered out of the bunch? Is it of order 1/2? A very rough estimate would do.
Edit, I should add that I read an accelerated beam might be used for a day and at the end of the day they dispose of the old beam. What is left of a typical beam bunch at the end of the day.
Thanks!
Which CERN accelerator do you mean?
LHC beams typically get dumped when ~1/2 to 1/3 of the initial protons are left. This is not bound to days, the accelerator operates 24/7. The beam is dumped when refilling (0 collisions for a while but then higher collision rates again) leads to a higher average collision rate than keeping the old beam.
You can watch it live here and here, "intensity" refers to the number of protons in the beams. Often the beams get dumped for safety reasons, that can happen much earlier (as it did yesterday afternoon for example).
I was thinking of our biggest and best, the LHC, right?
With that remaining fraction, call it one half for estimating purposes, should I be able to roughly estimate than the probability that a proton gets scattered from its bunch per interaction with a counter-rotating anti-proton bunch by estimating the total number of collision interactions in say a 24 hour run (about 4X10^9?)?
How many times per orbit around the ring does a bunch interact?
From this image can I infer that number is 4 interactions per orbit?
Thanks!
  • images?q=tbn:ANd9GcS4nuAE_IMMYz9VDcddFj3KqwQQVwb9jt4Amr_RKfm7HzzrTBU2.png
The LHC is the largest. The different accelerators all have different purposes, they are all best for their applications.
The LHC collides protons with protons. No antiprotons involved.
The LHC starts with close to 2 billion collisions per second in both ATLAS and CMS each, over time that rate goes down. The collision rate in LHCb and ALICE is much smaller. Some of the protons are lost due to other processes.
  • · Replies 69 ·
14K
  • · Replies 24 ·
  • · Replies 62 ·
  • · Replies 16 ·
