Remote Controlled Bowling Ball using Gyroscopes
12 replies · 5K views
Paradise_Bowler
TL;DR
I am making an RC Bowling Ball and need help getting pointed in the right direction with this project. Please help!
Ayyyyo! Science nerd here stopping by to check out what's going on in the physics realm and answer some questions I need answers for that will really help with my project. The project is easy to explain, I want to create a remote controlled bowling ball! To achieve this I was thinking of installing a battery powered gyro in a bowling ball synced to a wireless controller that can activate the gyro altering the bowling ball's path left or right. (for example, there is that mechanical gyro type that most people think of when they hear 'gyroscope', then the Powerball gyro type, and finally the gyro type with the 2 or 3 balls that spin around an axis).
The question right now is, what is the best type of gyro that can be installed in the core of the bowling ball that will almost instantly change the bowling ball's rolling path the most? Also, what other devices may be better than a gyro for this job? Finally, how should I go about installing the device making sure it is as stable as possible and won't break or fall apart after hitting the bowling pins?
If using a gyro how could I get the gyro to spin independently to the bowling ball? Besides the best, what could be the easiest and cheapest device/method? Thanks in advance, I'm really looking forward to what y'all physics geniuses think about this project.
If all you want to do it to "cheat" by making last minute adjustments to the balls trajectory, then a gyroscope system might be good.
But if you're looking for more control, I don't think a gyro is quite what you want. I would make a small, heavy RC vehicle and put it into a bowling bowl shape/size shell - with the shell being about a centimeter thick and made of bowling ball or bowling-ball like material. Then as the RC vehicle moves along the inside of the shell, it will power the bowling ball in the same direction of its movement.
Think Hamster Ball.
Reply
Think Hamster Ball.
Not trying to "cheat" anything but yeah, same basic effect of being able to grab it, throw it, and pull out a remote to make it change direction at the last second or a way to enhance the curve but still totally look like a normal bowling ball. That's just not possible with the wheel idea but I appreciate the idea none the less.
Back to the gyro idea though, anyone know a specific model or type that would work for my project?
If the ball contained a mass that could be shifted left or right, the curve could be controlled. If that mass was a heavy spinning wheel, then acceleration or deceleration (braking) of the wheel could also change the ball speed.
There little random moving balls sold as toys if various kinds (for kids, pets).
They work by having a small hollow low mass ball that contains a weight and a motor that moves the weight around to skew the ball's center of mass. They work pretty well, but are randomish.
This would be difficult for a bowling ball with its normal large mass.
Here are some search results: https://www.amazon.com/moving-ball/s?k=moving+ball&tag=pfamazon01-20
You will have a rolling ball, some internal control masses (spinning, static, or some of each), and some ability to apply force to those masses. You can pick a Cartesian coordinate system (x,y,z) to describe the positions within the ball of that internal machinery.
I think the biggest problem will be to combine the current rolling state of the ball expressed in the coordinate system, (it's position, spin axis, and velocity) and use that to execute the intentions specified by the RC user interface. Either the ball will be transmitting it's state to the RC unit where the operator command will be converted into control motions that are transmitted back to the ball. Or the ball will receive the RC operator commands directly, combine that with locally-collected ball state data, and determine itself what control operations will be required.
That second method has the advantage of reducing the signals that need to be exchange over the radio and of reducing any ball state latency to near zero. But it also means that you will need to do some embedded SW development on a uProc located in the ball.
What coefficient of friction are you looking at between the ball and the lane?
Most lanes, professional anyways vs the public ones, are oiled.
The 'turn left now' will surely have a delay.
Reply
The ball itself is a gyroscopically stabilised sphere. It will only be possible to make gentle changes to the curve and direction, or to the rate of ball rotation, (speed). Energy is limited internally by the rechargeable battery.
An internal spinning gyroscope would need to be floating, or by using a 9 variable integrated ultrasonic gyro, it could be fixed to turn with the ball. The mechanical construction of the internal mechanism will need to be dynamically balanced.
Normally a bowling ball changes direction because the left-right imbalance of mass relative to the contact point, results in precession of the ball to the left or the right.
The movement of a mass along the rolling axis, is the only way to vary from within, the left-right curve of the rolling ball.
Wouldn't that involve some pretty fiendish coordinate calculations? Where would left and right be? Whatever the solution, I'd imagine it would depend on the ball being launched in an odd sort of way; opponents would spot the difference, prolly.
No. The finger holes in the tenpin bowling ball, or the concentric rings on a lawn bowls ball, decide the axis of rotation when launched. If the ball is released normally it will be very repeatable. It must be repeatable, or there would be no skill in the game.
I believe you can get a small but heavy RC car, inside a big lightweight ball.
You must learn to drive the ball through the car.
The problem is then solved without gyroscopes.
Reply
Cool project! For steering a bowling ball mid-roll, a MEMS gyroscope + accelerometer combo (like the LSM6DSO 6-DOF IMU) would be far more practical than a mechanical gyro. It's compact enough to fit in the core, draws minimal power, and responds fast enough to give real-time orientation feedback to your control system. You'd pair it with a small brushless motor or reaction wheel mounted inside the ball on a gimbal-style frame so the motor spins independently of the ball's rotation, using the gyro's output to decide when and how much to correct the path. For durability against pin impacts, potting the electronics in epoxy resin inside the core cavity is the way to go. It absorbs shock and keeps everything rigid. Here's the datasheet [Link redacted by the Mentors] for the LSM6DSO if you want to dig into the specs and figure out if the sensitivity and output data rate suit your timing requirements.
