Removing an inside weld line in a pipe
  • Thread starter Thread starter Amir Sedieqy
    Line Pipe
The discussion centers on methods for removing the inside weld line of pipes with a 16mm outside diameter and 1m thickness to facilitate the smooth reciprocation of a piston. Participants explore various machining techniques, material options, and production considerations, focusing on both theoretical and practical aspects of manufacturing.
  • Experimental/applied
  • Some participants suggest machining the inside of LSAW pipes, while others propose cold drawing ERW pipes, noting concerns about surface smoothness and accuracy.
  • One participant mentions the possibility of using a reamer followed by honing for surface finish, while another questions the efficiency of this method for large-scale production.
  • There are suggestions to consider seamless steel or brass tubes, although some participants argue that these options may not be economical for large-scale production.
  • Another participant recommends using Drawn Over Mandrel (DOM) tubing, which has a smooth finish and tight tolerances, potentially eliminating the need for additional surface preparation.
  • Concerns are raised about the time-consuming nature of setting and centering parts for machining, especially given the high production rate of 1000 pieces per day.
  • Participants discuss the use of a circular broach as a fast method for weld bead removal and surface finishing, highlighting its advantages in terms of tool cost and simplicity of the jig required for operation.
Participants express a range of opinions on the best method for removing the weld line, with no clear consensus on the most effective approach. Multiple competing views remain regarding the feasibility and efficiency of various techniques and materials.
Participants note limitations related to the wall thickness of the pipes and the potential for radial deformations during machining. The discussion also highlights the need for practical testing before committing to large-scale production.
This discussion may be of interest to engineers, manufacturers, and designers involved in pipe fabrication, particularly those focused on high-volume production and surface finishing techniques.
Amir Sedieqy
What is the best and fastest way to remove the inside weld line of pipes with 16mm outside diameter and 1m thickness so a piston can reciprocate easily inside it? I have two options in mind. one is to have the inside of LSAW pipes machined, which might be laborious. The other option is to cold draw ERW pipes (I think cold drawing LSAW pipes would not result in smooth and accurate enough inside surface). I'm not sure whether either of these methods works. Is there a better way to to this? The end product is 12cm Cylinders which will be produced at least 1000 in quantity per day.
Welcome :cool:
How long is the stroke?
What are the materials?
What type of seal?
What fluid?
Thank you.
The stroke is 12cm, but I buy them as 6m or 3m steel pipes. They will be filled with nitrogen under 6bar pressure, so the seals are for gas.
Can you use a reamer? Something like this: https://www.mscdirect.com/product/details/81136251. Possibly followed by a honing operation depending on your requirements for surface finish. Reamers are also available in custom sizes if you cannot find a catalog size that works.
A twist drill could also work if you can tolerate a much rougher surface than that from a reamer.
Get tube with known outside dimension.
Mount tube in a jig that clamps and supports the entire length of outer wall.
Draw a lubricated circular broach through the bore, to remove internal variation and cut the final bore dimension.
Internal surface is then finished, with cutter lines on the surface in the same direction as piston travel.
The tapered broach would be made for the job, with several cutting edges, ground from tool steel stock.
So, in production you are thinking of buying something like 3km/month of this pipe? Unless you are only worried about prototypes/pre-production then you are definitely asking the wrong people here. You need to be speaking with high volume manufacturers of this sort of thing. They (each) know what they can do most effectively better than anyone else.
edit: You need to move past what you can buy from normal distributors or have machined at normal fabricators. This high volume sort of production is all about suppliers and tooling. You are thinking about your product design, which is ok at first, but you will need to be thinking about building a manufacturing facility or negotiating with large turn-key manufacturers to make this really work.
  • Love
I can use a reamer, but I'm not sure whether it is the most efficient way to do this at large-scale or not.
Lnewqban said:
There is no economic or practical way to machine that welded seam for 16 mm x 14 mm x 120 mm, keeping a perfectly round shape in my opinion.
Could you go with seamless steel or brass tube of dimmensions close to this welded pipe?
Please, see:
https://www.grainger.com/product/GRAINGER-APPROVED-6-ft-Seamless-1010-Carbon-3CCJ8
:cool:
Unfortunately, It would not be economical to use either seamless steel or brass for large-scale production.
Machining is going to be more expensive in the long run, I believe.
Consider that you only have 1 mm of wall to play with.
Holding the tube for machining may introduce radial deformations to that wall, unless fabricating and adjusting special jig, as explained by @Baluncore above.
Either of the tools mentioned above will work on removing metal from the seam, but they may remove some softer material from the thin wall that is located opposed to the seam.
I would run some practical test prior embarking in massive production.
Look into DOM (Drawn Over Mandrel) tubing. It has a smooth surface finish on both the inside and outside, and tight tolerances on diameter and wall thickness. You might not need any inside surface preparation. It's welded construction, but the weld line disappears after the drawing operation. And the wall thickness is much more consistent than with seamless tubing.
Setting and centering the parts in the tool and the process of machining are also time consuming: 1000 pieces per day means 2 per minute for a normal shift of 8 hours, which seems almost impossible to achieve with a shop tool such as a broaching machine.
Please, see:
https://en.wikipedia.org/wiki/Broaching_(metalworking)
:cool:
For quantity production go for drawn tube that does not require weld bead removal or surface machining. If you cannot do that for a prototype run then I suggest a circular broach because;
1. It is the fastest process available that will remove an internal weld and finish the surface, while avoiding tool marks that may damage the piston seals. That satisfies the OP weld bead removal in the fastest possible way.
2. Tool cost is significantly lower than expected since the broach tool can be made in a lathe or cylindrical grinder. It can be sharpened easily as required, without loss of profile.
3. The jig needed to hold the workpiece tube is also very simple to make. It can operate like a collet, that clamps the tube while the broach pulls the workpiece against a low end step in the jig.
4. Pulling will self centre the broach in the tube. If you have not used a broach before then you will not appreciate what can be achieved, or the elegance of the solution.
5. If throughput or reliability was a problem then, two machines with a shared pool of 5 broach cutters, would provide sufficient redundancy to maintain production.
  • Poll Poll
