Resistors in series and in parallel
The discussion focuses on calculating voltage, resistance, and current for resistors in series and parallel with a 20V battery. The user calculated total resistance as 77.92 ohms and total current as 1.54A, but questioned the current values for specific resistors. It was clarified that the voltage across parallel resistors is consistent and can be determined by multiplying the resultant resistance by the total current. The voltage across individual resistors can then be used to find the respective currents. Accurate calculations are essential for confirming the total current across the circuit.
Moninder
!20V battery.I need to Find Voltage, Resistance and Current in all resistors and total.
This is what I did so far.
Added 13ohms +15 ohms, then took all 3 of those and made it into one, whihc gave me 7.2258ohms.
Did the same for the 72 and 45 to get 27.7 ohms.
Then found the total resistance as 77.92 ohms. Found I total , current to be 1.54A
And for the 19ohm resistors I got V=29.26V I=1.54A
For 24ohm, V=36.96 I=1.54A
And I think for the 32 ohm V=29.26 I=0.91A
For 72ohm and 45 ohm V=27.7ohm and if that is it, should total current equal 1.54 instead of 0.88A?
How did you get the voltages in red?
The voltage is the same across all parallel connected resistors. It is equal to their resultant multiplied by the total current. The voltage across the 32 Ω resistor is the same as the voltage across the parallel resultant: 7.226*1.54. Dividing this voltage by the individual parallel resistances, you get the currents.
ehild
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
