I Reversible Measurement: Is It Possible?
A Puzzlement
Reversible computation is a somewhat well-known topic. (Quantum computers, for instance, must use reversible gates).
Apparently, though, quantum measurements can be reversible too. This also means you could recover the original state by “unmeasuring” the system. Imagine being able to “see” a photon without absorbing it!
So in theory should it be possible to have a robot or lifeform that interacts with its environment in a completely reversible way, dissipating no heat? Or at least one that comes arbitrarily close. (Of course, the environment would have to be fine-tuned, which I presume is why we don’t see reversible creatures everywhere).
Then again, a reversible lifeform might look so different from anything we’re familiar with that we’d completely miss it if it was there.
That's not what would happen. "Unmeasuring" would reverse the state of the measuring device and the environment as well as the measured system; so the result would be that you "unsee" and "unabsorb" the photon and have no memory of observing it.
Likes atyy and Demystifier
A reversible system is basically deterministic, so any "life form" would be acting like a machine, doing what it does with no surprises. Most definitions of life include some kind of metabolism, which is generally irreversible.
The reversibility they're talking about in the linked document has a non-negligible chance of failing.
What they're doing is a bit like taking a Bayesian prior and coming up with a test that has at least one outcome that will cause the prior to become a desired posterior. But if you run the test and get a different outcome (which must be possible unless the prior is already the desired posterior), you will get the wrong posterior instead. You can repeat the process, trying to craft a second test that has an outcome that will cause the first posterior to update into the target posterior, but this second test will have an even lower chance of success. Even with an infinite branching sequence of optimal tests prepared, the chance of not reaching the target posterior will stay bounded away from zero. The alternative would be like... if in reality you could make a drug work by doing weirder and weirder studies, instead of by designing the drug correctly.
The more useful your initial measurement is, the more likely it is that the reversing operation will fail. The more likely it is that the reversing operation succeeds, the less information you can get out of the measurement. These two effects will perfectly balance each other in a way that ultimately adds up to "useful measurement is irreversible".
Likes atyy and Mentz114
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
