Reversing Taifu QB70 single phase AC motor
The discussion focuses on reversing the direction of a Taifu QB70 single-phase AC motor for use in a gate opener project. The user initially attempted to reverse the motor's direction by manipulating the capacitor and leads without success. After guidance from a forum member, the user successfully achieved bidirectional rotation using a double-pole double-throw (DPDT) switch. Concerns about potential damage when running the motor in reverse were raised, along with inquiries about suitable switch types for controlling the motor's direction.
  • Understanding of single-phase induction motors and their wiring
  • Familiarity with capacitors and their role in motor operation
  • Knowledge of using a multimeter for resistance measurement
  • Experience with DPDT switches and their applications in motor control
  • Research the wiring configurations for single-phase induction motors
  • Learn about the function and selection of capacitors in motor applications
  • Explore the use of DPDT switches for reversing motor direction
  • Investigate potential issues and solutions for running motors in reverse
Electrical engineers, hobbyists working on motor control projects, and anyone interested in modifying single-phase AC motors for specific applications.
Nish6242
Hello Guys,
I got a Taifu QB70 water pump. But no more in use, I wish to use this motor in a gate opener project of mine.
However I cannot figure out how to make the motor rotate in a reverse direction.
What I tried ?
1. I reversed the position of the capacitor thinking it would provide reverse initial torque, in vain.
2. I reversed the intake leads of the motor(keeping capacitor leads intact), in vain again.
3. Changed the leads randomly (hoping it doesn't blows off LOL)... but in vain
THE MOTOR CONTINUES TO ROTATE IN A SINGLE DIRECTION.
Can someone help me making this motor work reversely (as well as forward also of course), use of external circuit with button or series of buttons is acceptable.
A single phase induction motor with a phase shifting capacitor usually has three terminals connecting to two separate windings. One terminal is common to the two windings, that connects to neutral. The other two wires connect to the active, but one has the capacitor in series. The motor direction is determined by which of the two active lines has the series capacitor.
@Baluncore ... Thanks a lot for the instructions. I got the motor rotating both sides now.
However, On rotating forward (its original direction) it makes a light humming sound, something as "VMMMMMMmmmmmmm"
But on getting it to work the reverse direction it makes a rather odd sound, something as "BRRRRRrrrrrrrr" (LOL).
I want to know it it would be anyhow destructive to use the motor in the reverse direction ?
NOTE: For my gate opener project i would need it to run backwards (pulling the gate) for about 30 to 40 seconds.
With the motor disconnected from the power and capacitor, use a multimeter to measure the resistance between pairs of the three wires. Two of the values should sum to the third. The highest value will be between the two active outer ends.
Are the two windings of the same resistance?
Check that you have the middle wire connected to neutral.
What does the motor sound like when it is turned by hand in either direction?
Hi @Baluncore, when turned by hand (in either direction) the motor does not make any sound, only feels a bit stiff (may be because the motor is a bit rusty).
Which switch allows this kind of flow ?
Guys can somebody tell me what kind of switch I can use to accomplish the flow depicted in the attachement (Reverse.png) ?
You have drawn a cross-over switch. Use a two pole, two position switch.
But to reverse a motor you only need to use a single two position switch.
Connect the capacitor between the two active terminals. Then distribute the active power to one side of the capacitor to go forwards or the other side to go backwards.
Might this be what you are needing? One DPDT switch can reverse the way the two input wires connect to the pair of motor wires.
  • · Replies 25 ·
  • · Replies 19 ·
