RF pulse detection with Power Detectors
6 replies · 15K views · last reply
Jiho
How can I use power detectors for RF pulse detection? RF pulse has a symmetric Gaussian-like shape.
Is the output of power detectors continuous line or point?
Welcome to the PF. :smile:
There are a number of different power detector types. Which type are you asking about? What is the repetition rate of the pulses (the duty cycle)? What power levels are involved? What RF frequencies are involved?
And is this really homework? If not, I can move your thread to the technical forums.
I'm studying how to catch pulse width without oscilloscope. Unknown pulse is from Q-switched laser which has a symmetric Gaussian-like shape.
If a pulse is sinusoidal wave form, the problem becomes quite simple. I can find exact frequency because Fourier transform of sinusoidal wave form has finite number of frequency.
Two plots: top, a sinusoidal-looking signal against time with peaks of equal height; bottom, a spectrum of peaks against frequency with a tall central peak and smaller peaks on either side.
But Fourier transform of Gaussian is Gaussian which has infinite number of frequency. That means each wave of frequency has different power. Is this right?
Two stacked line plots: the upper titled with a single narrow peak on a log-scale axis, the lower titled Power Detector Output showing a decaying curve against time.
This is the graph of power detector what I consider.
Line graph titled Output Voltage vs Input Power (A ratio), with output voltage on the vertical axis and input power in dBm on the horizontal axis, showing several downward-sloping curves for different detector models.
I can't come up with which value is output from power detector. I am confused that the output of power detector is just one value or a continuous liner value.
Unfortunately, I don't know the type of power detector. Also I will use just one pulse so the duty cycle is not taken into consideration.
And.. if possible would you kindly explain me relation between RF pulse detection and power detector or advise me a web site?
P.S)When I posted this thread, I didn't knew about specific categories. I should have posted on the technical forum.
  • Two-panel plot: top, red time-domain signal y against time (0 to 0.1 s) showing a periodic waveform with amplitude about 1 to -1.5; bottom, single-sided amplitude spectrum with peaks near 60 Hz (about 0.6) and 120 Hz (about 1.0) on a 0 to 200 Hz axis.
  • Two stacked plots: top, a Gaussian-shaped pulse in time (sec, 1e-8 scale) peaking near 0.5 at about 0.5e-8 s; bottom, its Fourier transform, a Gaussian-shaped curve in frequency (Hz, 1e10 scale) decaying from about 0.032 near 0 Hz to near zero by about 0.4e10 Hz.
  • Line graph titled Output Voltage Vs Input Power @ +25°C: output voltage in V (0.5 to 2.3) against input power in dBm (-50 to 20) for six frequencies from 10MHz to 8000MHz, with output load 1000Ω; the 8000MHz curve falls most steeply.
  • Two plots: top, a sinusoidal-looking signal against time with peaks of equal height; bottom, a spectrum of peaks against frequency with a tall central peak and smaller peaks on either side.
  • Two stacked line plots: the upper titled with a single narrow peak on a log-scale axis, the lower titled Power Detector Output showing a decaying curve against time.
  • Line graph titled Output Voltage vs Input Power (A ratio), with output voltage on the vertical axis and input power in dBm on the horizontal axis, showing several downward-sloping curves for different detector models.
If you want to detect the pulse width, you would use an envelope detector, not a power detector. Let me know the frequencies of interest and I can suggest an instrument.
(Thread moved from the schoolwork forums to the technical forums)
If you use a power detector, the output voltage is proportional to input power irrespective of wave shape.
A typical power detector for lower frequencies is a square law device, like a diode. At optical frequencies a photo diode performs the same function. If you apply a sine voltage wave, the output is its square. If we average this over a period of time we obtain the mean square of the input voltage, and so it represents the mean square value of the input voltage waveform, which is the power.
If you have a pulsed waveform, the average power can be found by measuring the output voltage with an averaging circuit, such as a resistor followed by a shunt capacitor, giving a long time constant. Then you measure the peak power, now using a small resistor with the capacitor, so that RF cycles are smoothed but the envelope fully charges the capacitor, so now we see the peak power in the envelope.
Using average and peak power you can find the mark/space ratio, or more accurately, duty cycle, as we do not know the pulse shape.
I have a Gaussian like shaped pulse waveform. It has 0.3ns pulse width, and it means 1.45Ghz half-band width in my calculation. If signal has 13dBm then what is output voltage from power detector? Is this enough information to calculate output or not? It's ok if I could get approximate value.
Plot titled Fourier Transform of a low-pass shaped curve, Y from 0 to 1.0 against frequency in Hz from 0 to 1e10, falling from 1.0 near zero frequency to near 0 by about 0.4e10, with an orange half-bandwidth marker at Y = 0.5 near 0.15e10 Hz.
Line graph titled Output Voltage Vs Input Power @ +25°C, plotting output voltage in V (0.5 to 2.3) against input power in dBm (-50 to 20) for six frequencies from 10MHz to 8000MHz, with output load 1000Ω; all curves fall roughly linearly, with the 8000MHz curve lying highest.
  • Line graph titled Output Voltage Vs Input Power @ +25°C, plotting output voltage in V (0.3 to 2.3) against input power in dBm (-50 to 20) for six frequencies from 10MHz to 8000MHz, with output load 1000Ω noted; all curves fall as input power rises, with the 8000MHz curve lying highest.
  • Plot titled Fourier Transform of a low-pass shaped curve, Y from 0 to 1.0 against frequency in Hz from 0 to 1e10, falling from 1.0 near zero frequency to near 0 by about 0.4e10, with an orange half-bandwidth marker at Y = 0.5 near 0.15e10 Hz.
  • Line graph titled Output Voltage Vs Input Power @ +25°C, plotting output voltage in V (0.5 to 2.3) against input power in dBm (-50 to 20) for six frequencies from 10MHz to 8000MHz, with output load 1000Ω; all curves fall roughly linearly, with the 8000MHz curve lying highest.
I don't like the fact that you have a DC offset on the power meter calibration. Best to re-draw the graph with 2.1 volts as the zero and reading upwards.
If 13dBm is the average power, then a power meter with an averaging CR circuit (or just a slow analogue meter) would read around 0.9 volt depending on carrier frequency.
If 13dBm is the peak power, then a power meter fitted with a peak reading capacitor will similarly read 0.9V. In this case I don't know what average reading you will get.
