Rigid Body Rotation Application
The discussion focuses on calculating the angular velocity (\omega) of a rigid body system involving two vertically oriented shafts connected by a cross member of length R, under the influence of a constant tangential load (F). The relevant equations include the rotational kinetic energy formula, K_{rot}=\frac{1}{2}I_z\omega^2, and the relationship between torque (τ) and angular acceleration (β), defined as β=τ/I. The torque is calculated as τ=R*F, leading to constant angular acceleration due to the fixed axis of rotation.
  • Understanding of rigid body dynamics
  • Familiarity with rotational kinematics
  • Knowledge of moment of inertia (I_z)
  • Basic principles of torque and angular acceleration
  • Study the derivation of angular velocity from torque and moment of inertia
  • Learn about the relationship between angular acceleration and time in rotational motion
  • Explore energy conservation principles in rotational systems
  • Investigate practical applications of rigid body rotation in engineering problems
Mechanical engineers, physics students, and anyone involved in the study or application of rigid body dynamics and rotational motion principles.
lanew
I'm trying to include rigid body rotation in a problem I'm working on but can't seem to figure it out.
Two shafts oriented vertically are connected by a thin cross member of length R. Holding one shaft stationary and applying a constant tangential load F to the other shaft will cause rotation at some speed \omega. Given the mass m and moment of inertia I_z. Is it possible to calculate the angular velocity?
Not sure what we need, but I believe it's going to involve energy.
Other than that I'm not sure.
No idea. I've been thinking about the problem for the past couple days but can't figure out how to determine the angular velocity given only these variables. If needed I may be able to supply other variables (this is a overly simplified example to give you an idea of the problem).
Thanks.
I have no idea about this problem without a picture... ehild
Applying that constant tangential force F means constant torque (τ=R*F) with respect to the fixed axis and constant angular acceleration: β=τ/I, where I is the moment of inertia, again with respect to he fixed axis. The angular velocity will change with time.
ehild
16K
  • · Replies 38 ·
  • · Replies 60 ·
