Rigid Body Rotation: Calculating Load Supported by Pivot
16 replies · 4K views
wolf party
imagine a thin length of wood supported by two supports, one at either end. One support dissapears and the other turns into a pivot (as gravity acts on the wood). Show that the load supported by the pivot is Mg/4.
i don't know where to start due to my confusion on forces with rotation. i know the plank is acted on by gravity at its CM, and its moment of inertia about its CM = I=1/12*M*l^2.
I know there is a reacton force at the Pivot, and this is the force i need to calculate, but i don't know what to consider first, a nudge in the right direction would be helpful!
Start by figuring out the acceleration of the center of mass. Hint: Apply Newton's 2nd law to the rotation.
F=ma -> TAU = I*ALPHA
TAU = (1/12*M*l*l)*ALPHA
so ALPHA = TAU/(1/12*M*l*l)
so a = (TAU/(1/12*M*l*l)) * (0.5*l) ? where a=ALPHA*(0.5l)
(1) It pivots about one end, not the center of mass, so correct the rotational inertia.
(2) What's the torque about the pivot?
TAU = (1/3*M*L*L)*ALPHA
the torque about the pivot is mgl/2 ?
so the acceleration due to gravity is a = 3*TAU/2*ML at the CM
and the torque about the pivot is mgl/2
so m*a = TAU*(1/2*l) ?
Good. So what's the acceleration of the center of mass? (Don't call it "acceleration due to gravity".)
Once you have the acceleration of the center of mass, apply Newton's 2nd law for translation. What forces act on the wood?
is the acceleration ofthe CM just 3TAU/2mL again
the reacton force at the pivot and mg at the CM are the forces on the wood
R = 0 because mgl/2 (where l = 0) = 0
therfore ma=mg ?
acceleration at CM = 3/4*g
But you know the torque, so eliminate Tau from this expression.
Good.
therfore ma=mg ?
No. Apply Newton's 2nd law. What's net force? The acceleration?
the force at the CM=3/4*mg
Net force at pivot = force at CM ?
That's the "ma" part of "Fnet = ma". But what's Fnet?
No. Two forces act on the wood (you named them earlier). Combine them to get the net force.
FNet = N - mg = 3/4mg
therfore N = 1/4mg ?
Careful. As written, this implies that N = 7/4mg. But the acceleration is downward, thus negative: N - mg = -3/4mg.
Yep.
