Rolling cylinder on cylindrical plane
The discussion focuses on the dynamics of a rolling cylinder on a cylindrical plane, specifically addressing the relationship between the angular velocities of the cylinder and the rod. Key equations include the translational kinetic energy (K.E) expressed as K.E (translational) = 0.5*m*v^2 and the rotational kinetic energy as K.E (rotational) = 0.5*I*omega^2. The moment of inertia (I) for the cylinder is determined using I (com) = 0.5*m*r^2, and the parallel axis theorem is emphasized for calculating the moment of inertia about point O. The consensus confirms that the angular velocity of the center of mass (CM) of the cylinder is equal to that of the rod about point O.
  • Understanding of rotational dynamics and kinetic energy equations
  • Familiarity with the concept of angular velocity
  • Knowledge of moment of inertia and its calculation
  • Application of the parallel axis theorem in physics
  • Study the application of the parallel axis theorem in various contexts
  • Explore the derivation and implications of the moment of inertia for different shapes
  • Learn about the relationship between translational and rotational motion in rolling objects
  • Investigate advanced topics in rotational dynamics, such as angular momentum conservation
Students and educators in physics, particularly those focusing on mechanics, as well as engineers and physicists involved in dynamics and motion analysis.
maffra
See attached
K.E (rotational) = .5*I*omega^2
K.E (translational) = .5*m*v^2
v(of rod and translational vel of cylinder) = L * (dαlpha/dt)
Is the angular velocity of the cylinder the same as the angular velocity of the rod?
To calculate the translational K.E of the cylinder can I use the vel I've calculated above for the rod?
For the rotational vel of the cylinder, can i use I (com) = 0.5*m*r^2
The angular velocity of the CM of the cylinder about O will be equal to the angular velocity of the rod about O. But the cylinder has a different angular velocity wrt its CM.
Yes.
Yes. But to find the MI about O, you have use parallel axis theorem.
  • · Replies 21 ·
  • · Replies 16 ·
