Rolling Dice Problem: Win 99% Probability with 5 Fair Dice
  • Thread starter Thread starter dspampi
    Dice Rolling
The discussion centers on calculating the number of times to roll 5 fair dice to achieve a winning probability of over 99% that all dice show different numbers. The probability of winning in a single roll is calculated as P(win) = 6!/6^5, which approximates to 0.092592593. Consequently, the probability of losing is P(lose) = 1 - P(win) = 0.907407407. To determine the necessary number of rolls (n) such that the probability of losing is less than 1%, the equation (P(lose))^n ≤ 0.01 is used.
  • Understanding of basic probability concepts
  • Familiarity with combinatorial calculations
  • Knowledge of independent events in probability
  • Ability to manipulate exponential equations
  • Calculate the exact probability of winning with 5 fair dice using P(win) = 6!/6^5
  • Explore the concept of independent events in probability theory
  • Learn about exponential decay in probability and its applications
  • Investigate simulations of dice rolls to validate theoretical probabilities
Mathematicians, statisticians, game designers, and anyone interested in probability theory and combinatorial problems.
dspampi
Consider the experiment of rolling 5 fair dice. You “win” if all the dice show different numbers. I have to decide in advance how many times to repeat the experiment.
I will be very happy if I win at least once. What is the least number of times I need to plan to repeat the experiment so that my probability of winning at least once is more than 99%?
So there is an equal chance that one of six possibilities are possible for for each dice roll.
The first roll will have a different number = 1; 2nd is different 5/6, 3rd is 4/6, 4th is 3/6, 5th is 2/6 and the 6th is 1/6...so is the probability just the multiplication of all the chances and how do I get to 99% confidence?
Are you sure you are setting up the problem correctly? To me, it reads that in each round of play you roll all 5 dice at once, and win if all 5 numbers are different. If so, then each round of play is independent of the previous, unless you have already stopped because you have already won. If my interpretation is correct the problem is just like that of tossing a biased coin and winning as soon as you get 'heads'.
RGV
As RGV says, you are rolling 5 dice at a time. The chance that all 5 are different can thus be calculated - let's assume it is 20%.
That means there is an 80% chance you have not won.
You now work on the probability of NOT winning.
If you roll again there is now a 64% chance you have not won [80% of 80%]
You want to calculate how many rolls until the chance you have not won is less than 1%
If there is less than 1% chance of NOT winning, there must be a 99% chance you have won.
Don't forget, I "made up" the 20% probability for explanation purposes; you need to use the real answer.
Ok well I agree that all 5 dice are being rolled at the same time so I think regardless that
P(win) = 6/6 * 5/6 * ... * 2/6 = 6!/6^5
and P(lose) = 1 - P(win) = 0.907407407
So to calculate the rolls that I have lost down to 1%,
is that just (P(lose))^n = 1?
That is correct, except it should be <= 1 , not just =1 , with n an integer.
And 1% is a probability of 0.01, not 1
Indeed!
  • · Replies 53 ·
9K
