Rotating a 5m Cylinder: Calculating Initial Torque for Motor Capacity
The discussion revolves around calculating the initial torque required for a motor to rotate a 5-meter-long cylinder with specific performance criteria. Participants explore the relationships between torque, angular acceleration, and motor capacity, with a focus on both theoretical calculations and practical applications in motor selection.
  • Sunovya describes a project involving a bearing-supported cylinder and requests assistance in calculating the initial torque needed for motor capacity.
  • One participant asks about the basic kinematic relationship between torque and angular acceleration.
  • Another participant provides detailed calculations for the moment of inertia, angular momentum, and torque, concluding with a starting torque value of 1437 Nm for the cylinder's acceleration.
  • Bob discusses a different scenario involving fan starting times and presents a method for estimating starting torque and acceleration time, including various coefficients and inertia values.
  • Bob calculates the total torque required to accelerate the impeller and discusses the implications of including a loss coefficient in the calculations.
  • Paul seeks clarification on the torque formula and its components, particularly the meaning of the variables involved.
  • Bob explains the terms related to angular speed, acceleration, and momentum, drawing parallels to linear motion concepts.
  • Another participant practices calculations for a motor's starting torque and acceleration time, questioning the necessity of the loss coefficient in their approach.
  • Sunovya expresses gratitude for the assistance received in the discussion.
The discussion features multiple competing views on the calculations and methodologies for determining torque and motor capacity. There is no consensus on the best approach or the necessity of certain coefficients in the calculations.
Participants rely on various assumptions regarding motor performance, inertia values, and coefficients, which may not be universally applicable. The discussion includes different scenarios and calculations that may not directly correlate with each other.
sunovya
Sir,
I stuck with a project. It is a bearing supported 5 Meter long cylinder with 1.5 meter diameter and weighs approximately 8 tons. At first stage I need to rotate this cylinder from 0-200 RPM within 1 minute and keep that RPM for 10 minutes and again from 200-1200 within 1 minute and keep this RPM for 30-45 Minutes, then bring down to 0 RPM, using a speed controlled(ATB) A/c Motor with suitable reduction gear system.
Kindly advice how to calculate the Initial torque to find out the correct capacity motor for this project
Thanks
Sunovya
What is the basic kinematic relationship between torque and angular acceleration?
Here are properties of the cylinder
Mass = M =7300 Kg
Radius R = 0.75 meters
z = length = 8 meters
Moment of inertia = I = MR2 = 4106 kg m2 (hollow cylinder)
w = radians/sec = 2 pi RPM/60
Energy E = (1/2)I w2 = (1/2) M R2w2
Angular momentum is J = I w (kilogram-m2/sec)
Torque L = I dw/dt
(kilogram-m2/sec2 = Newton-meters)
If the cylinder is accelerated from zero to 200 RPM in 60 sec, this is equivalent to 0.35 radians per sec2.
The starting torque is 4106 x 0.35 = 1437 Nm
Bob,
You seem like a really clever guy, i wonder if you can help me find an easier formula for fan starting times regarding motors.
At current we use a really long winded formula.
i'll try to explain the best i can.
First of all we have to find the starting time and loss coefficients that we have to use a chart. if we have say 15 Kw absorbed power we may use say 18.5 Kw motor so firstly we do this.
15000 Watts / ( 18500 x 1.7 ) = 0.48 we then look at the starting time and loss coefficient graph which would be 1.24.
1.7 is what we estimate for starting torque vs normal torque.
so starting torque will be estimated (18500 x 1.7) / (2 x pi x revs per sec (24) ) = 208 Nm
we then need to know the rotor inertia and impeller inertia, so if the rotor inertia was 0.12 kg m^2 and the impellor inertia was 30 kg m^2 we use the following calculation.
lets say the impeller is 12 revs per second.
1.24 x (2x pi x 24) / 208 Nm x ( 0.12 + 30 x (12 / 24 ) ^2 ) = 6.85 secs starting time.
I will try to answer your question, although I do not understand the source of all of your numbers. First, at full speed (1440 RPM), your motor can supply
18,500 x 60/(2 pi RPM) = 122 N-m
Your load requires
15,000 x 60/(2 pi RPM) = 99 N-m
The total torque to accelerate your inertia at dw/dt is (using full RPM of impeller is half the rotor RPM)
L = I dw/dt = 0.12 dw/dt + 30 x 0.5 dw/dt = 15.12 dw/dt = 208 N-m
So dw/dt = 208/15.12 = 13.8 radians/sec2
1440 RPM = 151 radians per sec.
So time to accelerate to full RPM at no load and 208 N-m torque is 151/13.8 = 10.9 seconds.
[Added text] I did not include your loss coefficient of 1.24. If I include this factor, the accelerating time to full RPM at no load would be 1.24 x 10.9 sec = 13.9 sec.
I hope this helps.
Bob,
Thanks for your reply, just a quick question what is L = I dw/dt ? i take it I= inertia? can you explain the rest please.
cheers Paul.
Hi Paul-
w (actually lower case omega) is commonly used as the angular speed in radians per second, so for example
w = 2 pi RPM/60.
Then dw/dt = angular acceleration in radians per sec2.
Then torque L = dJ/dt = I dw/dt
These are analogs of
p = linear momentum = m v
Force = dp/dt = m dv/dt
Bob S
Bob,
I'm having a practice, can you confirm if I'm going right.
motor = 1440 rpm - 22 Kw, starting torque = (22000 x 1.7) / (2 x pi x24 ) = 248 Nm
Rotor inertia = 0.14 , Impellor inertia = 16, Impellor speed = 1600 rpm = 26.66 rps
L=I dw/dt = 0.14 dw/dt + 16 x 1.111 dw/dt = 17.916 dw/dt = 248 Nm
so dw/dt = 248/17.916 = 13.84 radians/sec^2
1440 rpm = 24 rps = 24 x 6.283 = 150.79 radians per sec
Acceleration time therefore equals 150.79/13.84 = 10.89 secs.
I don't think using your way you need the loss coefficient?
Dear Mr Bob,
Thanks you very much for the reply. It was very useful to me
Thanks & Regards
Sunovya
  • · Replies 17 ·
21K
  • · Replies 42 ·
15K
10K
