Rotating Disks - How to calculate final KE?
  • Thread starter Thread starter taveuni
    Final Rotating
The discussion centers on calculating the final rotational speed and kinetic energy loss when two disks interact. The first disk has a mass of 350 g and rotates at 154 rpm, while the second disk, weighing 260 g, starts from rest. The final speed after friction is calculated to be 112.9 rpm. The user attempts to compute the kinetic energy lost due to friction but arrives at an incorrect value, suggesting a miscalculation in their equations. The conversation highlights the importance of accurate calculations and assumptions regarding the moment of inertia when analyzing the system's energy changes.
taveuni
Hi, I have worked through this problem for so long that I cannot see how I could be getting it wrong. I feel like I am doing it correctly, but I don't get the right answer.
QUESTION
A disk of mass M1 = 350 g and radius R1 = 10 cm rotates about its symmetry axis at finitial = 154 rpm. A second disk of mass M2 = 260 g and radius R2 = 7 cm, initially not rotating, is dropped on top of the first. Frictional forces act to bring the two disks to a common rotational speed ffinal.
a) What is ffinal? Please give your answer in units of rpm, but do not enter the units.
ff= 112.9 rpm​
b) In the process, how much kinetic energy is lost due to friction?
|KElost| = ? J​
MY THOUGHTS:
I figure that the change in KE is equal to .5*(Ii*wi^2)-.5*(If*wf^2). KEi is easily calculated and is 0.22756 J.
Is it fair to assume that the If in KEf is the sum of the I's for both disks, because they are now spinning together? I did that, came up with I(sum)=0.002387, which gives a If of 0.11683.
KEi - KEf = change in KE
0.22756-0.11683 = 0.06073 - which is wrong.
Should I be incorporating translational KE into this? I tried that and also go the wrong answer.
Thank you for your insight.
Here is your problem. 0.22756-0.11683\neq0.06073. Looks like you pushed the wrong buttons on your calculator :smile:
