Rotating wheel initial angular velocity given final and time
2 replies · 9K views
vinnyzwrx
A rotation wheel required 3.0 s to complete 37 revolutions. its angular speed at the end of the 3.0 s interval is 98 rad/s. what was the original angular speed of the wheel?
average omega = change in angle/change in time
heres my thought on the answer, i wanted to make sure its right since i don't have the correct answer to compare my thoughts
i find the average angular velocity by 37*2pi over 3
since the acceleration is constant the average angular velocity is at 1.5 s
so then i find the difference between final angular velocity which is at 3 seconds and the velocity at 1.5 seconds which is 20.51 and subtract that from the average angular velocity to get the angular velocity at 0 seconds.
the final answer is 56.89 since the velocity at 1.5 seconds is 77.49
is this thought process correct, it seems to be from my point of view.
That works (though you should check your final answer, it looks like you have a couple digits flipped around.
You can also do this with
[tex]\omega_f^2 = \omega_i^2 + 2 \alpha \Delta \theta[/tex]
and
[tex]\alpha = \frac{\omega_f - \omega_i}{\Delta t}[/tex]
I think your way is probably simpler, but requires breaking the problem into two steps. However, you do avoid having to solve a quadratic equation.
