Rotation Operator: Spin 1/2 vs Spin 1
  • Thread starter Thread starter M. next
    Operator Rotation
M. next
How does finding the rotation operator for a spin 1/2 particle differ from finding that of a spin 1 particle?
if you have the generators (angular momentum operators) then its practically the same thing you just exponentiation.
Im not sure if that's what you're asking..
Thanks for your reply, but I was pointing to a different road, my question in other words is how to derive, rotation operator for spin 1? How do we get there?
How did you find the rotation operator for spin 1/2? You probably started with the rules for the generators J_i, namely the commutation relation
[J_i,J_j] = i \epsilon_{ijk} J_k
and the eigenvalue conditions
J^2 | j,m\rangle = j(j+1) | j,m\rangle,~~~J_3 | j,m\rangle = m | j,m\rangle .
You then have to choose a set of basis vectors to correspond to the states | j,m\rangle. You can choose a basis so that J_3 is diagonal. From here, you can use trial and error to find a pair of matrices that have the correct commutation relations with J_3 and satisfy the J^2 equation. Otherwise you can form the raising and lowering operators
J_\pm = \frac{1}{\sqrt{2}} (J_1\pm iJ_2),
J_3 J_\pm | j,m\rangle = (m\pm 1) | j,m\pm 1\rangle
and note that
J_+ | 1,1\rangle = J_- | 1,-1\rangle =0.
These last conditions can be solved with less guesswork.
Once you have the generators, you can exponentiate them to find the rotation matrices.
Can entangled spin 1/2 particles have time rate of change spins ? +-+-+-+- Or is spin a fixed value ?
Thanks for your reply, but actually I didn't use this way.
We were trying to solve it without using the matrix-method. We know that rotation operator about some axis of unit vector u equals to exp[i/\hbar*uSθ]
Then I can manipulate that and use Taylor's expansion to expand the exponential and then separate the terms into odd powers and even powers to end up with using again the Taylor's expansion but now to compile the 'odd' 'even' terms.
Then what procedure should be done to know spin rotation operator for spin equals 1?
If not what is the correct thing to do?
Thank you a lot.
It is simple,the generators here are like e(imθ) for rotation about z axis,where m=1/2 for spin 1/2 and m=1 for spin 1.i.e. replace θ/2 by θ.
Thank you, i tried it and it worked! Thank you andrien.
