kikidoll
- 9
A 750 gram grinding wheel 25.0 cm in diameter is in the shape of a uniform solid disc. When it is in use it turns at a constant 220 rpm about an axis perpendicular to its face through its center. When the power is switched off the wheel stops in 45.0 s with constant angular acceleration due to friction
A) What is rotational intertia of the wheel?
B) What is the initial angular velocity in rad/s?
C) What is the constant angular acceleration in rad/s^2?
D) What is the magnitude of the torque exerted by friction in N-m?
m = 0.750 kg
r= 0.125 m
wf = 23.04 rad/s (converting 220rpm)
t= 45.0 s
Part A) Idisc= 0.5(mr^2) = 0.5(0.750kg)(0.125m^2) = 5.86*10^-2 kgm^2
I was thinking along these lines... I could find part C first (angular acceleration - alpha) and use that to find part B (initial angular velocity - w0) by using this equation : wf = w0 + alpha(time). I could then find part D (torque - T) by using this equation : alpha = T/I
My problem is finding angular acceleration, or alpha.
This is what I did, please let me know if it's correct or not.
v(speed)= radius*wf
v = (0.125m)(23.04 rad/s) = 2.88
vf= v0 +a(linear)(time)
2.88 = 0 +a(45seconds)
a(linear) = 0.064 m/s
a(linear) = radius*a(angular)
0.064 = 0.125*a
alpha = 0.512 rad/s^2
If it's wrong, could you please advise on how to get the right answer?
Thank you in advance :)Disclaimers: This is my first post, so please be gentle! Also, this is not homework, it is a practice test. Thanks again!
