RPM Limit on Theoretical motor?
The discussion revolves around the concept of using a gas as a flywheel for energy storage, exploring the feasibility of spinning a conductive gas using electromagnets. Participants consider the implications of energy density, efficiency, and the mechanics involved in achieving high rotational speeds.
  • Some participants propose the idea of using a gas instead of a solid flywheel to avoid the risk of explosion.
  • Concerns are raised about the low energy density and efficiency of a gas flywheel compared to solid materials.
  • Participants discuss the mechanics of spinning a gas and the challenges of inducing a state where gas particles have an orbital trajectory.
  • One participant mentions the potential to switch electromagnets at high speeds, referencing experiences with small induction machines.
  • There is a discussion about the limitations of using ions and the effects of relativistic speeds in cyclotrons, with some suggesting that these concepts may not directly relate to flywheel applications.
  • Another participant draws analogies to natural phenomena, such as the Sun and galaxies, to conceptualize the desired gas behavior.
  • Some participants express skepticism about the practicality of achieving high speeds with neutral gas particles and the challenges of maintaining a stable configuration.
  • One participant shares thoughts on related technologies, such as vortex tube coolers and MHD generators, suggesting potential avenues for exploration.
Participants express a range of views on the feasibility and practicality of using a gas as a flywheel. There is no consensus on the effectiveness of this approach, and multiple competing ideas and concerns remain unresolved.
Participants highlight limitations related to energy density, the behavior of ions, and the challenges of maintaining a stable gas configuration. The discussion reflects a variety of assumptions and conditions that are not fully resolved.
Warpspeed13
Ok so I was trying to design a flywheel for a project of mine and an idea occurred to me. Why not use a gas instead of a solid wheel so you didn't haven't worry about it exploding? Could you spin a conductive gas using electromagnets situated around the gas chamber? Whats the maximum speed at which you could switch the electromagnets with today's technology to maximize the speed?
I would guess the low density and fluid friction would mean it would have terrible energy density and efficiency
What's a gas wheel?
Flywheels store energy by virtue of their rotational inertia. For a flywheel made from a solid circular cylinder, the mass moment of inertia I = mr2, and the amount of energy stored when the angular velocity of the flywheel is ω rad/sec is:
E = Iω2 = mω2r2
By making a 'wheel' out of gas, the mass m will be much smaller than if the wheel is made of metal, and the amount of energy which can be stored for a given angular velocity will be proportionately reduced.
I'm ok with low energy density I'm more interested in creating something that would spin the gas at very high rpm. Not so much for a useful purpose but as something interesting to do.
Ok a more accurate description would be to induce a state in the gas in which the majority of the gas particles have an orbital trajectory about a single axis.
This depends on size and construction of machine. Out of curiosity, I've done some short high speed test runs on small induction machines (Pn< 3 kW) up to 10 000 rpm. They all survived . Big machines (Pn>1 MW) would probably selfdestruct much more before that.
You mean like The Sun?
I don't see how you would get the force right for neutral particles. You can collect a cloud of ions, of course, like a small cyclotron. They can reach relativistic speeds, but the density is extremely low (and you get synchrotron radiation) - not practical as energy storage.
Hadn't thought of that comparison but you basically.
Ok cool. So the limit is constrained by how effectively you can bend the trajectory of the ions around the track.
Cyclotrons are limited by relativistic effects and at some point the size becomes impractical. Even higher energies can be reached with other accelerator types. That has nothing to do with flywheels any more, however.
That's just a definition of the word "spin". I'm asking physically how you hope/plan to do it. I'm unable to envision the concept.
Think like a cd or a galaxy or the event horizon on a black hole. I want to use electromagnets to create a similar state in a body of gas. Since the gas if ionized will be attracted to the negative pole on an electromagnet I want to use electromagnets in a circle to rotate the body of gas around the center of a container at high speed.
That's fine i,m not looking to accelerate anything to close to light speed. Id prefer to get a larger amount of gas ionized or not,moving at a couple hundred m/s
When I was a kid, I would drive past industries that generated a lot of dust, and I'd regularly see cone-shaped air cleaners. They used to capture my imagination.
http://en.wikipedia.org/wiki/Cyclonic_separation
These were constructed from galvanized steel and would be about 6-8 feet in diameter. It was a good use of spinning air as it captured a massive amount of pollution.
Your thoughts remind me of how I found out about MHD generators,...they were around a few years before I imagined one in my mind.
I was thinking about alternators and how spin speed and heat would bring them to a state of shrapnel, the idea that came sounds similar to what you are describing.
Things you might consider...
The mechanics of a vortex tube cooler (spin speed of the air)
An alternator with all components ground to a fine powder
A sandstorm with silicon particles in suspension
Mix a quantity of iron and copper powder in the vortex flow, guided through a magnetic field.
Feeding particles in a layering pattern where they produce an electrical current, then draw from that, would be the goal to reach.
Spin speed and heat becomes almost irrelevant. Participial mass and speed determine voltage and current, recycle of the powders should be easy enough.
An alternator of sorts that has a very high wear factor, but super cheap to replace :approve:
Perhaps there is something in that dribble that coincides with your thoughts, or maybe will trigger in your mind a thought that makes your vision click. :)
A couple of hundred meters per second is possible with conventional solid flywheels.
You can't get a large collection of ions. Every ion has at least one elementary charge, if you have too many they repel each other too much.
10K
  • · Replies 18 ·
