Runge-Kutta Projectile Approximation From Initial Conditions
The discussion focuses on implementing the Runge-Kutta 4th order (RK4) method for projectile motion simulations in Excel, building upon an initial implementation using the Euler method. The user, @VexCarido, seeks guidance on translating initial conditions into a function for RK4, specifically how to derive the function of the ordinary differential equation (ODE) from given parameters like starting position and velocity. Participants suggest resources and emphasize the utility of Excel for foundational scientific programming, despite its limitations compared to dedicated programming languages.
  • Understanding of numerical methods, specifically the Euler method and Runge-Kutta 4th order (RK4) method.
  • Familiarity with projectile motion physics, including the effects of gravity, drag, and wind forces.
  • Basic proficiency in using Excel for numerical simulations.
  • Knowledge of ordinary differential equations (ODEs) and their applications in motion analysis.
  • Research the derivation of functions for ODEs from initial conditions in projectile motion.
  • Learn how to implement the Runge-Kutta 4th order method in Excel.
  • Explore programming languages like Python or MATLAB for more advanced numerical simulations.
  • Investigate resources comparing different numerical methods for ballistic motion, particularly RK2 and RK4.
Physics enthusiasts, educators, and students interested in numerical methods for simulating projectile motion, as well as anyone looking to enhance their skills in scientific programming using Excel.
VexCarido
Hi everyone. I'm a new member, great to be here:)
I have a few questions that I wanted to ask you guys regarding the method by which we implement the Runge-Kutta approximation of Projectile Motion if we should do it using a numerical iterative method with a Spreadsheet like Excel.
I have already constructed a simulation in Excel using the Euler method basic physics formulas and implemented both gravity, drag and wind forces. Now I wish to improve upon the accuracy by using a better approximation of the X,Y coordinates over time with RK4.
Here's how I constructed the spread sheet with The Euler numerical method (using gravity, but ignoring drag and wind):
and I suppose these are the formulas that should use to get the improved approximation with the Runge Kutta Method:
To clarify, I am trying to get a list X, Y coordinates as function of time, using a set of initial conditions. The initial values should be able to be freely changed to get approximations of any type of movement along the x-y plane.
I hope my phrasing & terminology is sufficient. This is mostly a DIY project, not homework or school related.
Hi @VexCarido and welcome to PF.
:welcome:
You said you have a few questions. What are they?
:welcome:
I thought it may have been clear from OP, but it may have been too broad. I'm trying to get an understanding of how to relate a set of initial conditions to the evolution of motion, using the RK4 method, in a similar fashion to what you would do with the Euler-Cromer method.
That is, I have an object a x,y position thrusted in any direction with a specified velocity. Using Euler's method I use the simple iteration of x= vx*dt+x, y=vx*dt+y formula.
How can I use the RK4 to solve the exact same problem? I recon I need to calculate the value of the function "f" ? How does one go about it?
My goal is to then compare the two solutions to see how much they diverge over time when I plug in different initial values.
Here is a short video that I found with minimal search to get you started. I hope it helps. I am sure there are other examples on the web if it doesn't.
Unfortunately the video skips a couple of steps in relation to my question and I have looked at other videos that also seem not to mention how I get the function of the ODE from a set of initial conditions.
In this video he uses f=3X^2Y. If I need to go from the information(Example); Starting point (0,0) velocity = 75/ms at (35) degree angle and translate this info into a function, what would be the appropriate steps then?
Have you seen this?
kuruman said:
Have you seen this?
No, that particular site escaped my search and it does in fact provide some very useful info. Thanks.
Only problem is that it deals with RK2, not 4. Hopefully I will be able to deduce the logic behind it and modify it to suit a forth order approximation instead.
Is there any particular reason you are using Excel for this instead of a programming language that is more suited to numerical simulation?
This post might help:
https://scicomp.stackexchange.com/a/21063
This paper compares different methods for ballistics:
https://www.researchgate.net/publication/333985200_Two_Numerical_Algorithms_for_the_Ballistic_Motion_Equations
I have been thinking that Excel serves as a very sound starting point for my practice in scientific programming & creating physics simulations. It is very suitable as you are working at a truly fundamental level with all the equations of physics without the need for knowing additional coding languages.
I was inspired by a couple of different persons online who showed me the versatility of the program given a little know-how & I'm confident I'll be able to translate a lot of the knowledge directly to a range of programming languages moving forward.
If you want to see some of the awesome capabilities of Excel (particularly the 2003 version) i suggest you check out this website.: http://www.excelunusual.com/
Or this Youtube Channel (same guy):
  • · Replies 65 ·
  • · Replies 16 ·
