Can Humans Run Vertical Loops? The Science Behind Running Feats
  • Thread starter Thread starter Loren Booda
    Running
Humans cannot realistically run a vertical loop due to the physics involved, even if theoretically possible at top speeds. The centripetal acceleration required to stay on the loop exceeds what a human can generate, especially when considering energy loss and friction. Calculations suggest that a runner maintaining 10 m/s could complete a 10m high loop, but this is impractical given human energy limits. Additionally, running at the bottom of the loop would subject the runner to 2G's, further complicating the feat. While some may achieve a similar effect by running up a wall and flipping back, true vertical looping is beyond human capability.
Loren Booda
Theoretically, can a human in 1g circuit completely a vertical loop solely by running?
What's a "1g circuit" ?
Let's say that top speed for a human is 10m/s. (Faster than me, but Carl Lewis can do it.)
The centripetal acceleration is \frac{v^2}{r}. In order for the runner not to fall from the top of the loop he must be at least in free fall at the top of the loop. So we get
\frac{100\frac{m^2}{s^2}}{r} > 9.81 \frac{m}{s^2} \rightarrow r < \frac{100}{9.81} m
So if the human could maintain top speed all the way up, then it would be possible for someone like Carl Lewis to run a loop that was 10m high.
This is, of course, unrealistic. According to the same calculations, someone who can run 5m/s should be able to run a 3m high loop. (This is not possible -- at least not for normal humans)
There are major factors that the calculation ignores - one is that the amount of energy that goes into going up the loop while maintaining that speed is quite large -- certainly larger than what a human can produce -- that there will be a loss of friction as the runner goes up the loop which increases the problems with energy consumed by climbing , and also that, for a circular loop, the runner would be pulling 2G's while running at the bottom of the loop.
Depending on how you define running a loop, running up a wall, and then flipping back would qualify. This is something that people can certainly do (watch "Singing in the rain" for a spectacular example.) Based on footage like that I would say that at least some humans can run loops.
NateTG
Depending on how you define running a loop, running up a wall, and then flipping back would qualify. This is something that people can certainly do (watch "Singing in the rain" for a spectacular example).
With wingtips yet. Thanks for your competent delineation.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
