Guineafowl
- 967
- 422
- TL;DR
- What cheap and practical steps could a hobby workshop take to limit the damage caused by VFDs to old motors not designed for them?
The ‘spiky’ output of variable frequency drives (VFDs) can damage the insulation of older motors. They’re often used to run three phase motors on single-phase supplies in hobby workshops. (Modern motors have upgraded insulation and are designated ‘inverter-duty’.) I wonder what cheap and practical steps one can take to mitigate this, given that dedicated sine wave filters are quite expensive. I think most of us quietly ignore the problem and hope for the best.
Apparently, the motor windings themselves act as quite good low-pass filters for the current, and that it’s actually the voltage rise time that causes the problem. The high dv/dt pulses result in reflected waves sloshing back and forth due to impedance mismatch. These waves add together in the cable between VFD and motor, leading to high voltage transients that damage old motor insulation.
^^ I’m sure this is a poor summary, and also sure that you could write a whole monograph on the subject. But, down to brass tacks, what practical steps could we take in a hobby workshop with several old motors on VFDs?
1. In-line chokes, such as old fluorescent light ballasts, providing they could take the rated current?
2. Keep the VFD-motor cable short, and manipulate the VFD’s carrier frequency based on this length?
3. MOVs, or something, to clip the transients? I looked into the surge protection devices (SPDs) now becoming more readily available because they’re mentioned in the new UK domestic mains wiring regulations, but they are apparently not sensitive enough.
4. Some sort of snubber network at the motor terminals?
